Hello,
The sequence unit in my Lido keeps resetting spontaneously during the search cycle. In the middle of a search cycle, it will reset and not register a win. This seems to only happen when the machine is closed. When I open it up and put it through a couple search cycles and watch the CU cam 16A it works absolutely fine and resets normally after stepping to the max position. I checked the CU cam 16A and it seems to be working fine (winner unit reset coil is working as it should). Originally I thought it was a mechanical problem (possibly vibrations from the pulsing sequence step up coil) I moved the sequence unit tension spring one loop around to see if that was the problem. But the random resetting is still arising. I am stumped on this issue any ideas or recommendations would be greatly appreciated.
Thanks.
