Good afternoon,
My Williams Liberty Bell has a problem where the outholes will not kick out the pinball when it falls into them, seems to happen randomly. If a Tilt is caused, it will spit them out. When the pinball sticks in the holes, and after powering off the machine, a click is heard after being off for about 5 seconds. I assume that is the Pause relay disengaging. After turning the machine back on after this audible click, the problem stops until it decides to start doing it again. Which is about every 10-20 games or so. I assume the culprit is the pause relay staying engaged longer than what it's intended to. I am not sure of the cause.
Thanks for your help in advance.
