I'm just setting up WOZ in my new home, and even though my basement floor is PRETTY darn level based on the three previous Stern pins I've levelled, I'm having a problem finding enough range on an original first-run WOZ ECLE.
With the back feet cranked all the way down and the front feet all the way up, I'm only measuring 5.5 degrees between the flippers, and even less in the upper half of the playfield. There's literally no more range available for me to adjust. So... uh... I guess I need to steal the MUCH longer feet from the front of my Hobbit? Or is WOZ not actually supposed to run at 6.5 degrees?
