One common problem I see in older machines are that the inserts are not level with the playing field. From what I've seen, this usually happens in one of two ways.
1) The insert is raised above the playfield.
2) The insert is 'cupped' - meaning the edges of the insert are level with the playfield, but the insert itself is somewhat melted downward.
I did a quick search, and didn't find any existing topics here - so... I'm curious as to how any of y'all have fixed these problems. I think #1 is a pretty easy fix, as I've been able to gently tap down the raised inserts, and apply super glue as needed to get them to stay down (some don't need glue at all).
It's the 'cupped' inserts that I'm really curious about. I've read about some people applying thin clear super glue right on top of the insert...but haven't been brave enough to try it. I've also read about people completely removing the inserts and heating them enough to flatten then out. But again, I've been too scared to try it. Any suggestions or comments??
