The Token sign came from a Vendor that had an arcade that they closed in the early 2000's. It was their only location that used tokens and they tossed the sign aside and forgot about it until they were moving to a new building in 2019. It was in a pile to go to the dump so I offered the 20 bucks.
The chase lights were quite a project and there was probably a better way to do it than what I did.
I bought the Lenses, Covers, and mount form Action Lighting. They are Cabochon E14 MIDWAY U90 Turbo Lights.
https://www.actionlighting.com/cabochon-e14-midway-brand-u90-turbo-fixture-bases-bases-only-300u90b/
I mounted the black bases to a piece of wood I painted silver by drilling two small holes in then and mounting them with small screws, then drilled out a hole in the middle (where the real bulb mount is supposed to go) and ran a set of LED Christmas lights through each hole. It’s 4 sets of Christmas lights, every 4th lens is the same set of lights, I have Red, Yellow, and Orange lenses, witch match the Red, Orange, and Yellow I picked for the Arcade in my sign. When I finally paint the stripes on the wall they will be those same colors to match as well.
Those 4 sets of lights are then plugged into a 4 channel sequencer for Christmas lights I bought off Amazon.
https://www.amazon.com/gp/product/B00DHPLK9K/
A lot of splicing and a lot of soldering, but I’m thrilled with the end results so it was worth it.
