New! Dark mode!
(Topic ID: 1058)
Let's see pics of game rooms!
By erak
10 years ago
  • 16,234 posts
  • 1,900 Pinsiders participating
  • Latest reply 17 hours ago by TUFLYF
  • Topic is favorited by 830 Pinsiders
    There have been 11,292 images uploaded to this topic. (View topic image gallery).
    There are 16234 posts in this topic. You are on page 320 of 325.
    33
    #15951 40 days ago
    New neon in the DOMINO Arcade
    Will do an update video shortly but the place is in a bit of a mess as I've been adding Scorbit to all my games they currently support.
    30
    #15952 40 days ago
    Little update
    #15953 40 days ago
    Looks nice! What are the black boxes on the ceiling made of, painted plywood? and it looks like they may be lit around the top edges?
    #15954 40 days ago
    Quoted from gorditas:
    The best analog that is available most places is rock wool. Great sound deadening and fire rating properties.
    This is what I used at my two properties. Rock wool is easy to install (for the most part), deadens some sound, increased fire rating ,and is not organic thus lowering mold potential.
    #15955 39 days ago
    Quoted from JRBBRJ:
    I second this - I used the same product and thicker drywall on part of my basement build and it worked with fantastic results. Really lowered the sound and now can play games late into the night without waking the kids. Only bleed I have is from the HVAC vents...
    38
    #15956 39 days ago
    This is the first time all my games have been together. Just got the carpet in the other day and my buddy spent a few hours last night and then this afternoon helping me move games around.
    My basement is really close to being finished. Just some granite and a door to the theater.
    #15957 39 days ago
    Quoted from ReadyPO:
    It's basotect - it helps to reduce Sounds and give a nice accoustic
    https://www.eurokustik.com/english/acoustic-foam-decor-basotect-50-adhesive-meplde50ad.html
    It's a difference between nicht and day. The little room ist not so loud now
    #15958 39 days ago
    Quoted from shirkle:
    Thanks guys. Yeah, I was planning on 5/8” drywall with fiberglass insulation. Will the insulation even help? Again, not looking for silent, just dampen it down to a mild background noise.
    I put in regular insulation. It does help alot.
    #15959 39 days ago
    Quoted from Spyderturbo007:
    Very nice. The entire place looks like a survival kit to me.
    19
    #15960 39 days ago
    Been a little busy the past few days. Got the addition's upstairs cleared and cleaned up
    enough to start running the electric. Years back, I ran the leads before the downstair's
    ceiling was put in..
    #15961 38 days ago
    Quoted from tomaszb1:
    A trick on the vents is to use flex duct, even if it's only a few inches long on each connection. Metal ducts are more efficient for airflow, but transmit sound quite well. Those few inches of flex decouple the pipe and stop sound transmission, and if installed properly, don't add drag. Don't forget to do this on the supply and return connections. On a related note, I recommend putting your returns near the floor. Physics causes cold, dense air to collect in the basement. You can use this to your advantage in the summer by picking this air back up and recirculating it. That design, coupled with a dehumidifier has kept the temperature the same in my basement as the main floor.
    14
    #15962 38 days ago
    Check out this radical blacklight mural we did as we continue to finish our retro arcade/mini golf.
    I might move and if I do I'm going to have my entire new basement themed in blacklight! These pics are for those pac man fans!
    #15963 38 days ago
    [quoted image][quoted image]
    We just got the same dehumidifier Tuesday. Loving it so far. Super quiet and efficient. Basement humidity is between 40 and 50
    #15964 38 days ago
    Quoted from dirkdiggler:
    Did you get yours at Costco too?
    #15965 38 days ago
    Yup. Our old one finally bit the big one a couple weeks back. Great price too. The 50 pint from Costco was cheaper then 35 pint from other retailers and less then half what Wal-Mart wanted for a 50 pint. Only downside was waiting a week for delivery. It's so nice to have the air at a healthy level instead of the high 80s/low 90s.
    #15966 37 days ago
    I tied my dehumidifier into the condensate pump line of my furnace. That way the water gets pumped out and I don't have to manually empty it ever. About once a year scum builds up in the drain line and blocks it. But it's easy to remove the hose and clean it. If you don't have a furnace condensate pump already, I recommend buying one and tying it into your sewer line. Manually emptying these things every day is a PITA!
    #15967 37 days ago
    Quoted from Mr_Outlane:
    Mine empties into the sump pump. You are right, emptying them gets old rather quickly.
    #15968 37 days ago
    Tell us more about those light fixtures please...
    Looks great!
    #15969 37 days ago
    Quoted from sataneatscheese:
    Looks great!
    I had thought about making them since they are just galvanized pipe, but it would have probably taken me about 25 trips to Home Depot, so I decided to just buy them. I got them from a small company in Utah.
    I have a few pictures of them in my build thread too.
    https://haddockindustrial.com/black-pipe-wall-sconce-or-ceiling-fixture-industrial-lighting-steampunk-light/
    https://pinside.com/pinball/forum/topic/game-room-build-thread/page/5#post-4106387
    #15970 37 days ago
    We're filling a bucket every 8 hrs trying to catch up for the week it wasn't running. It is a major pita. Going to hook it up to a hose for continous drain and drain it down the sewer.
    Curious on how much you guys run the dehumidifier? We talk to people here in our town and they run them 24/7 year long. I'm thinking 4 hrs on, 4 off. Wife thinks one day on, one day off. Thoughts?
    #15971 37 days ago
    I run mine 25/7, but not on full blast. I run it at about 6 or 7 out of 10 and usually have to empty it out every 3 or 4 days.
    #15972 37 days ago
    This totally depends on climate. Once the furnace comes on here in Michigan, I have to add humidity. I have my dehumidifier on auto, and it isn't running as much now that temperatures have dropped to less than room temperature for most of the day. In a week or two, I'll put it away. I've got a whole house humidifier, and I usually set up another unit in my music room for my instruments.
    #15973 37 days ago
    When I finished the basement I bit the bullet and paid $1200 (installed) for a "whole home" dehumidifier unit that work in tandem with my basement HVAC and it was the best investment I could have made. It uses the same vent / returns as the the current system and ties into the existing condensate pump. It comes on automatically to maintain whatever humidity level you set. Never have to empty it and just change the filter on it same schedule as the main unit. Have never had to deal with humid or musty basement, it literally feels like the rest of the house regardless of the weather or seasons.
    #15974 37 days ago
    You live in some sort of alternative universe ?
    #15975 37 days ago
    In the spring, summer and fall months, continuous on full blast. In winter, it almost never kicks on. This is just for my basement. Upstairs is AC for dehumidification and a humidifier for winter.
    #15976 37 days ago
    Quoted from Thor-NL:
    We have 25 hours one day a year here.
    You guys are incredible. I live in a tiny house in a shed with no heater or airconditioner, let alone a machine to take the humidity out of the air. It's like you live in a fish tank sealed away from the world.
    I mean you can't even open a window.
    No criticism, just trying to imagine, but i don't think i could be happy living like that.
    #15977 37 days ago
    Ha! No alternative universe, just fingers too fat to hit the right computer keys.
    #15978 37 days ago
    For anyone interested in our inaugural episode of JOBLO COLLECTOR'S CORNER (featuring all things BATMAN '89) check out the video below, which features the awesome gameroom from "Tim from Tennessee" from these very forums (starts around 10:35 in the video). If you want your own gameroom/collection featured in a future episode, please let us know via the contact info found here: https://www.joblo.com/movie-news/are-you-a-collector-show-us-your-collection-for-our-latest-video-series
    #15979 37 days ago
    Quoted from punkin:
    A shed with 20 pins? count me in!
    #15981 37 days ago
    Ok the posing is hilarious
    #15982 37 days ago
    Quoted from RetroGamerJP:
    I did the same thing, but also have a second "zone" for just the basement besides the HVAC system that has ducting to areas in the basement. It helps to circulate the air in the basement as well.
    #15983 37 days ago
    Quoted from Mopar:
    Man you have been busy. I remember seeing an older pic of that room packed to the gills. Did you ever get around to fixing up that coin changer?
    #15984 37 days ago
    Quoted from cait001:
    Web call it 'the teapot'.
    No idea how it started, but it's now compulsory.
    25
    #15985 35 days ago
    Since the last set of gameroom pictures I have added a Jurassic Park Pro to the main arcade area. I also sold my rebound shuffleboard and replaced it with a Pop a Shot, an air hockey, and a 50s diner for my girls. We are spending a lot more time in the gameroom since I added more fun stuff for my daughters (3 and 7). Also got a compact sectional loveseat to replace my old couch so that I could fit two games on that wall.
    21DB24AC-F22A-4EAB-8261-A363533EE10D (resized).jpeg8B340B61-5852-462B-A357-71BEA41B3DF8 (resized).jpeg39E50422-82CA-4F3A-9EB6-DBF66ED7964D (resized).jpeg2B49B5C3-82D3-4310-B99E-047309E26787 (resized).jpeg
    12
    #15986 32 days ago
    Had a little party last night and took this picture. Thought it was pretty cool!
    #15987 31 days ago
    Quoted from BeeGeeMtl:
    Thanks to the team at JOBLO - if anyone is considering doing this, it was super simple and easy to participate in
    You may have a non-pinball collection to showcase as well - they are looking for anything unique really
    #15988 31 days ago
    Quoted from MT45:
    They reached out to me to feature my game room for a future episode.
    #15989 31 days ago
    Quoted from Waldo:
    You've got a killer setup!
    Would be an awesome segment if you decide to do it
    36
    #15990 31 days ago
    Small but, I love the heck out of my current setup!
    25
    #15991 31 days ago
    Small update. Traded deadpool premium for a Wonka(my first jjp). My daughter loves it! Room on the right for Avengers Premium whenever it comes...
    #15992 31 days ago
    is wonka not a widebody?
    #15993 31 days ago
    Pat don't widebody Both DI and WW are standard body games.
    #15994 30 days ago
    Quoted from weaverj:
    glad it isnt! I cant fit a widebody down my stairs! Plus I tend not to like widebodies in general. Enjoying Wonka so far
    #15995 30 days ago
    new addition to the gameroom today
    #15996 30 days ago
    Forgot the touchscreen kiosk pic;
    #15997 30 days ago
    Quoted from punkin:
    Thats great fun to have with friends during covid. I can't even get anyone over to play.
    #15998 30 days ago
    Quoted from punkin:
    What is your high score?
    #15999 30 days ago
    Quoted from jorge5240:
    Had a little party last night and took this picture. Thought it was pretty cool![quoted image]
    Did you build that infinity table? It's great!!
    Also, I'm curious what you used for that cool bar. Looks like some kind of backlit printed image?
    #16000 30 days ago
    Quoted from punkin:
    Please report back how this works out. I have wanted a commercial breathalyzer for a while but I haven’t pulled the trigger yet. I liked the looks of this one but have heard conflicting reports about how good it is.
    $ 28.95
    $ 9,999.99
    Little Shop Of Games
    $ 75.00
    Latenight Weeknight Mods
    $ 24.00
    The MOD Couple
    CzTV Mods
    $ 6,995.00
    Classic Game Rooms
    Metal-Mods
    $ 24.95
    Hookedonpinball.com
    $ 999.00
    $ 159.00
    $ 86.95
    $ 98.00
    $ 29.99
    Cobra Amusements
    $ 9,099.00
    $ 5,899.00
    Classic Game Rooms
    $ 12,500.00
    Nitro Pinball Shop
    $ 214.99
    $ 45.99
    Lee's Parts
    $ 139.00
    Sparky Pinball
    $ 5.00
    Doc's Pinball Shop
    $ 80.00
    Back Alley Creations
    $ 36.99
    Lee's Parts
    $ 76.95
    $ 29.00
    Filament Printing
    $ 159.99
