Quoted from ramegoom:Although I started a separate thread on the build of my game room, here are some images of the end result, fitting the title of this thread. Missing a few key items, but basically all there and ready to fire up. I was fortunate in that I had 2900 sq. ft. of space to "have at it". So I did.
After having a couple of months under my belt of room usage, and moving a few machines around, I have the following observations:
1. Keep pins separated by at least 15 in. in order to have access to the back box without disturbing the footprint.
2. If you have any bowlers, you need to keep a distance apart from both the back wall and the right side; you will need to open the machines occasionally (hinged right) and access the rear of the back box.
3. Overhead lighting is critical to the pinball areas. You need to avoid glare from the can lights which would be seen on the glass by the machine player. Keep the lighting at a steep angle to the glass and you will avoid that.
4. I didn't finish the ceiling and am forever glad that I didn't. I have since put extra electrical outlets in various places to accommodate string LED lighting along the entire perimeter of the walls and those outlets, placed strategically, made life simple. Since I blacked out the ceiling, a quick flat black rattle-can touch up for electrical outlets and wiring, and you'd never notice them. I put the Ebay LED string lights up using those 16 color controllers, linked each power outlet with remote outlet controls from Amazon, and have currently settled on the lowest intensity blue lights all around. Way cool.
5. Lack of carpet makes moving the machines around much easier. I went with a metallic floor surface, and have waxed it with "Cherry Wax" to give the gloss shine a shot in the arm. Cleanup is a snap using a dusting mop. And, mopping the floor near the outside entrance is easy and effective. Spill a glass of wine, no problem. After two former carpeted game rooms, I can say I'd never recommend carpeting again. Polished or coated concrete is the only way to go.
6. I was concerned about lack of ceiling insulation and potential noise, but it turned out well. The overall noise from pins, bowlers, arcade machines and slot machines turns out to be a great mix of ambiance, and you can still hear the TVs over it all.
7. The heating system really doesn't get much use. With all machines in operation, total heat generated warms the room nicely. I'll probably be complaining about it this summer, but that's what air conditioning is all about.
8. I added several outlets at 6 ft. off the floor for neon signs, so no cords are visible. That was a good move, but I kind of wish I installed more of them. Placement of neons can be convenient if you have more outlets to choose from. No real downside to too many outlets.
9. I installed a small angle-shaped "Prize Cage" and so glad I did. Lots of kid stuff in the room, and the cage does the trick. Loaded with cotton candy, mini Chinese gumball machines and small toys, the kids have a memorable visit there. They trade tickets won by the skee ball machine for prizes. The crane game and skee ball keep kids in their own little world. And, all the tokens for multiple slots are stored there.
It's been a fun project so far.
