I have a spare green 7 digit X-pin that I could lend out for testing. PM me your info if you want it.
GPE also has 2N3584's for $5.00ea
https://www.greatplainselectronics.com/proddetail.asp?prod=2N3584
Unofficial, totally amateurish temp test on the heatsink. Using a meat thermometer suspended between the inner fins around the LM323K.
Space Invaders. Double glass with chaser lights in a widebody cabinet, door closed. 5 LED displays. One hour on attract mode reached a max of 135F. Started a four player game. 5 minutes into it the 5A fuse blew. Temp was 140.
EBD, standard cab with fake plastic back glass and five gas displays. Max temp at any time 120F.
Quoted from Mk1Mod0:Unofficial, totally amateurish temp test on the heatsink. Using a meat thermometer suspended between the inner fins around the LM323K.
Cool! Thanks for running your own test with temps, nice to see similar results. I didn't try with the 3A linear regulator because I already had a 78H05 unsoldered from a board..and also figured that way I wouldn't be limited for testing with all 4x led displays connected, or even adding a 5th.
I haven't gone back to testing temps after a longer period of time with just plasmas connected, so that's nice to know on your EBD the max was 120F. I wasn't seeing temp go up much after about 20-30 min and figured it wasn't going to climb too high from there.
I doubt it blew over temps since its well away in the lower cab. The fuse is new as is the rectifier board. Yikes.
Quoted from Mk1Mod0:I doubt it blew over temps since its well away in the lower cab. The fuse is new as is the rectifier board. Yikes.
Update: Got confirmation of which fuse blew for Mk1Mod0.. it was F4 (49VAC) so may have been unrelated.
Quoted from acebathound:Update: Got confirmation of which fuse blew for Mk1Mod0.. it was F4 (49VAC) so may have been unrelated.
Unless a drop in 5V cause some kind of solenoid driver glitch to lock on a coil.
Bally's reset circuit monitors the 11.9VDC, not the 5VDC. So a dip in the 5V could cause a software issue while not causing a full reset.
Put it on attract mode for an hour followed by non-stop four player games for an hour. Never topped 135F. Not one glitch. Not one blip. Displays look fantastic.
Part II - Received the EZSBC module today. A 5A replacement for the LM78HO5. Went ahead and reinstalled the gas displays to get a baseline. Believe it or else, 138F. So 140F with the LED displays seems not so bad. Hoping the 5A PSU7 will bring it down a little and help it all last a little longer. So I removed the 7805 from the solenoid board and replaced it with the PSU7. Replaced all gas displays with all LED displays. Pulled the fuse for the high voltage circuit. And fired it up. Blows F3 every single time within 3 seconds. A little disappointed and unsure of where to go from here.
Quoted from Mk1Mod0:Melted R50. WTF?
Yikes. As far as I'm aware that should have been a drop-in replacement. The only thing that was recommended was to replace R50 and replace with a jumper. And also remove R49. But, didn't seem like there was danger in leaving them.. just that they weren't needed & would just put additional unnecessary load on the regulator. Anyway, don't replace or remove anything just yet, it's probably best to check with Daniel @ EZSBC just to see if he has an idea of what might have happened and how to proceed. Looking at detail at the pictures of a PSU7 on the website it seems like there's a few traces running very close to one of the screw holes.. wondering if that may have had something to do with it. Only thought I have right now.
Sorry to hear about that.. hopefully it's not too much trouble to get resolved
You now have a switching power supply going in there instead of an old linear supply. The ground current can be quite high for normal operation of a switching supply. You do NOT want R50 in there for a switcher, replace it with a stout wire.
I can't tell from the photos on their website but are there any traces on the underside (besides a ground plane)? The PSU5 I have doesn't but it is also much more forgiving around the mounting holes than the PSU7 appears to be. So Ace may be right if your mounting hardware has either a larger washer or a star washer that may be touching any of the surrounding traces.
They really need to include a warning sheet for anyone that plans to use these on the Bally Regulator boards to install a jumper in R50.
Plus, with R50 burnt open, there is no path to ground for the regulator and there is the possible potential for feeding 11.9VDC to everything on 5V depending on how the switching circuit acts when ungrounded.
Post incident, I replaced the resistor and removed the EZSBC to swap back to the original component. Machine fired right up, so no harm, no foul. (One crispy resistor, a burned spot and one lifted trace. Nothing here I have not seen before.) Tomorrow I will replace R-50 with a stout jumper and try, try again.
Quoted from CactusJack:I can't tell from the photos on their website but are there any traces on the underside (besides a ground plane)? The PSU5 I have doesn't but it is also much more forgiving around the mounting holes than the PSU7 appears to be. So Ace may be right if your mounting hardware has either a larger washer or a star washer that may be touching any of the surrounding traces.
Nail on the head here. Let's go to the tape!
Quoted from Mk1Mod0:Nail on the head here. Let's go to the tape!
It's late so I could be looking at it wrong, but the filled zone with the Tasmanian Devil character (or close enough resemblance anyway) seems like it'd be 12v (connected to the leg on that side). A smaller filled zone on the other side (the one connected to the other leg) is 5v. Anyway, from the bite marks it looks like 12v would have shorted to GND.. if that's the case, probably dumped 4A to GND and blew the fuse. Maybe the 2.2ohm resistor took some of it too since it wasn't that much resistance.. and just blew. Not sure how the regulator would fair in that scenario.
Then it looks like fiber or nylon washers are in order as well as the directive to remove and resistors in line with ground (R50 on Bally) before installing the 5 amp version.
Aren't you glad you were our ginnea pig?
Quoted from CactusJack:Then it looks like fiber or nylon washers are in order as well as the directive to remove and resistors in line with ground (R50 on Bally) before installing the 5 amp version.
Only thing with fiber/nylon washers is, what's making the ground connection then? I think it needs the top-side mounting hole pads on the PSU7 to make the connection, as the SDB only has pads on the back of its board. To make matters worse, the top mounting hole on the SDB doesn't connect to ground -- there's no physical trace to ground for that pad on the back of the SDB. There may be some clearance issues with traces around that hole as well.
If the regulator survived this, I'm not even sure how I'd recommend reconnecting it. Maybe without the star washer if that keeps the head of the screw away from any of those other filled zones. Seems a design change is needed here for sure..
I don't think I'd "try again" on this one until Daniel was notified (if that hasn't been done yet). He should know about any possible issues with mounting these & could also direct you in what to do next with the regulator.
That's how it appeared to me. The star washer bit right into the neighboring area and created a mess. Hopefully it still works. I'll be looking at perhaps a small lockwasher or something similar. The footprint of the star washer is too dang big and a connection is needed to reach ground. Here's a back side shot for ya.
I don't mind being a guinea pig as long as others learn from my mistakes. We shall see...
I would guess that the short you had completely bypassed all the PSU7 circuitry so it probably survived.
That is a VERY small clearance surrounding the pads. You cannot use an insulator there as you need the electrical interconnect. A small diameter washer such as a NAS620 is probably what you need there.
Quoted from G-P-E:I would guess that the short you had completely bypassed all the PSU7 circuitry so it probably survived.
Hope so!
Quoted from G-P-E:That is a VERY small clearance surrounding the pads. You cannot use an insulator there as you need the electrical interconnect.
Noted.
Quoted from G-P-E:A small diameter washer such as a NAS620 is probably what you need there.
A flat washer (like Ed suggested) in combination with star washer would be my personal choice. With a star washer you damage the circuitboard; cuts through the copper.
Installed and humming right along. Literally. The sound feedback is so bad I can barely make out the sounds of the game. Any suggestions?
I'll put out a temp report after an hour on attract made.
Quoted from Mk1Mod0:Installed and humming right along. Literally. The sound feedback is so bad I can barely make out the sounds of the game. Any suggestions?
Sound feedback wasn't there with the linear back in it yesterday?
Quoted from acebathound:Sound feedback wasn't there with the linear back in it yesterday?
Nope. this has actually been one of my quietest machines. Only my 6M$M was louder. On the other hand,
100F !!!!! Holy crap! That's a 40 degree drop for cryin' out loud! Sold.
Quoted from Mk1Mod0:Nope. this has actually been one of my quietest machines. Only my 6M$M was louder. On the other hand,
I've read through the updates on this thread and I understand the need for clearance on the pads. I'll improve it soon. I don't understand the audio interference since the switching frequency is 800kHz, I think. It's certainly above 500kHz. This design is a lot noisier than the PSU5 because of the higher switching frequency, high peak currents and inductor shape but since it is so far above the audio range I didn't expect problems.
It costs a bunch of money to bring a design that like this into production. For a simple design its in the $400-$500 range for setup costs in the PCB factory, a solder paste stencil and wasted material when setting up the pick and place machine and the reflow oven. I have two options here, keep the design and fix the clearance issues only and live with the noisy design. Or go into another round of development to try to fix the noise issue with no guarantee of success. All feedback and suggestions appreciated.
I can also make a 4A version that is as quite as the PSU5. It can be used where the PSU5 doesn't supply enough current but the noise is an issue.
May I use these photos on my site for an installation guide?
Can someone post the part numbers for those screws and where I can buy some for sizing of the mounting holes.
Should I sell properly sized mounting screws and washers on my site or do you re-use the existing ones?
I'm learning a lot here.
Daniel
I think verification that the audio circuit is being affected on a few other machines would be a good first step, since at this point it's just been noticed on a single machine. Would there be any way to pin-point it as the issue (ie. would a scope on part of the audio circuit show the 800kHz frequency if that's what was causing the hum?). I'm pretty sure most of the sound boards in these machines operate off of 12v unregulated DC and some even create their own 5v supply off of it.. but I'd guess that the switching regulator frequency could feed back into the source voltage as well?
After seeing what was done with smaller washers, the clearance issue doesn't seem *as bad* to me. I think having the option of buying appropriately sized screws/washers as an add-on at time of ordering the regulator would be great! So maybe a small notice about possible clearance issues if using the original washers/screws and not to use star-washers (or really any washer) that extends far outside the mounting hole pads.
Great to see you're on-top of things here and welcoming of the feedback!
Quoted from Daniel5:I've read through the updates on this thread and I understand the need for clearance on the pads.
The pads are good, it's an application problem. Dummy end-users like me are going to use whatever is available or closest at hand without a second thought. In this case I used the existing hardware and you can see what happened. I would maybe have a note regarding the need to ground it at the pad with respect to washer size. IE- "washer O.D. should be no more than x mm in diameter." Or buy a box of 100 at a local hardware store and send them along with it. Two sets nut/bolt/washer might come out around $.05 per order in the end with no appreciable weight to add to shipping costs. I get the expense of refining a PCB run. The design is fine, just gotta educate the monkeys out here.
As for the noise issue, I wouldn't sweat it right away. I'm doing a lot of repairs/upgrades to this machine and it just happened that after installing the PSU7 the feedback took a big jump in volume. If I get a chance later today, I have another Bally out in the garage set up and I will swap in the SDB with your module and see what happens there. It's a common problem with these early Bally S/S machines. I only mentioned it because it was so noticeable. A cursory review of the schematic shows this particular sound card runs off 5v all together. I'll take some readings at the test points and see what we got. Results to be posted later.
Thanks for looking in on this. I'll be at TPF setting up Thursday afternoon and you are welcome to come and check out the machine for yourself. The way I see it, once I get some LED GI bulbs in the backbox I may get it down to near room temperature. Nice.
Shawn
And feel free to use my pictures as you need.
At work, companies always include new mounting hardware with replacement boards, because too long of screws may ground the board to a non-reference ground.
They know that in the field where many techs may have serviced equipment, there could be an assortment of screws installed as replacements.
Same with these Bally regulators. Who knows what different sized lock washers were lost and replaced, or even substituted by Bally themselves over the years?
Much safer to include the proper size washers, and note their importance in the installation instructions.
Best solution imho would be, to use smt washers soldered on the board by the manufacturer, so the end user only needs 2 srews.
http://www.smtnet.com/news/index.cfm?fuseaction=view_news&news_id=4248
OK, so all the test points on the sound card tested well within standards.
Next, I tested the board in my EBD and found NO appreciable difference in the amount of feedback between a normally configured SDB and one with the PSU7 installed. The EBD has normal gas displays.
Next I retested the Space Invaders using a the normal board first, then the one with the PSU7. You can hear the difference for yourself. I changed nothing between the videos except for the SBD board.
Without PSU7 -
With PSU7 -
Looking at the schematics, the Eight Ball Deluxe sound board has its own LM323 +5V regulator, whereas the Space Invaders sound board is using +5V from the solenoid driver board (PSU7 in this case).
Presumably some will use the PSU7 for other (non Pinball) applications and they will have different length screw requirements.
I'd prefer a larger screw face area on the next batch of PSU7 to eliminate screw head issues altogether.
Daniel, I presume it's OK from the pic above but are any of the vias on the bottom of the PSU7 live? i.e. can one bolt the PSU7 directly onto a heatsink without fear of live vias inadvertently shorting to common/ground? Some will probably remove the heatsink but I'm one that would prefer to leave the heatsink there so anyone in future could easily revert to the original regulator for whatever reason.
Can you simply upgrade the PSU5 to 4A or does it need the expense of a new design?
Hopefully you and Mk1Mod0 can catch up at TPF and do a little analysis of the humming issue.
It appears that his thread is becoming one about PSU7 regulators. My question is if it makes sense to install the lock washer underneath the board, between it and the heat sink? It does not serve a locking function as much as a bite and it has a thru trace.
Quoted from Platypus:It appears that his thread is becoming one about PSU7 regulators. My question is if it makes sense to install the lock washer underneath the board, between it and the heat sink? It does not serve a locking function as much as a bite and it has a thru trace.
Do you mean between the back of the regulator and the top of the heat sink? Or between the bottom of the heat sink and the top of the SDB?
While that washer might bite into the aluminum heat sink thereby grounding it, it may be difficult to insure a good contact with the regulator's ground at the surface of the heat sink (black ones are anodized) and the back of the regulator module has solder mask covering it. And it almost would seem like overkill to have to use a star washer between the regulator and heat sink AND the heat sink and SDB PCB pad.
I would instead use a star lock washer on the underside of the PCB where it can bite into the ground pad unless you are using a "kep nut" (the kind where the star washer is part of the nut).
A simple split lock washer the size of the screw could be used on the top side at the PSU7 pad but I have mixed feelings on this. By using a washer, you introduce a second surface where we have to insure good electrical contact but the cut of the split washer may do a good job cutting into the pad and screw head. Hard to know without doing actual tests under heavy current loading.
It might be just as good to leave it out and to just make sure to completely clean the underside of the screw head (wire brush) or use brand new screws to insure good contact with the regulator's pad. But I would definitely use one on the underside of the SDB PCB.
The noise would have to be on the 12v line to come through the speakers... no? The amplifiers are powered by 12v.... unless the sound generator is effected and it comes from the analogue output there.
Could the 12000uF filter cap be failing on the board making excessive hum? Can you check the ripple on the 12v line?
Quoted from barakandl:Could the 12000uF filter cap be failing on the board making excessive hum? Can you check the ripple on the 12v line?
Board was recapped and all ground mods completed two years ago.
No clue how to check the ripple on the 12v line. Not even sure what that means. If it can be done with a dmm, I can do it. No o-scope in this house.
Quoted from Mk1Mod0:Board was recapped and all ground mods completed two years ago.
That will all depend on how your DVM reacts to AC on a DC voltage. What you do is set your meter to AC. Lock it in to a low setting if you can (2 or 20 volts if available). An auto range is pretty useless unless it has the hold feature.
You should see less than 1 volt of AC across the 11.9vdc across the filter cap.
If your meter won't tell you the presence of AC, then you might see the normal DC reading fluctuate when the buzzing increases (high score displayed).
Some really cheap meters may just tell you that there is 2X the 11.9v there because of how they read AC. If you get a reading higher than a few volts, disregard it. Your game would not be functional if there were like 5-6 volts AC on the unregulated 11.9.
Fluke 115. Set to AC MIN it read 0.00 with ground on SDB ground and pos on either side of the 12,000 cap at any point in the high score / last game score cycle.
Posting these pics for reference and because I said I would when they arrived.
These are two LT1003CK 5V linear regulators which were designed as a 5A replacement for the LM323 with some better characteristics.
Both purchased over ebay from China. The old one date stamped 9306 was sold as used. The newer one date stamped 1048 was was sold as new. Based on previous pictures they don't look fake. I've even soldered the top cover back down on the old unit and am currently running it in my machine for test (amusement
Old one:
www.ebay.com/itm/151896786969
The two legs were normal length so had never been cut. Maybe they were just old stock.
New one:
www.ebay.com/itm/201024477998
Erm, I just noticed they have none left however what I got came with a business card from these guys so this is the original source of the newer ones and they still have stock:
www.ebay.com/itm/261235641206
Thanks for posting the links. I just ordered 3 off the first link since there were still 17 left (now 14). I figured it was worth it just to make sure my 78H05K drawer wasn't empty!
Thanks again for being the guinea pig and posting the results!
My pleasure, it was thanks to your idea of cutting the head off to look inside and prove those cheap LM78H05 were fake.
BTW, both of these came well packaged, unlike the fake LM78H05 which came with legs sticking out from an envelope!
I installed the psu7 tonight and here is how it went. Didn't read this thread and just pulled the old regulator and heatsink and installed the psu7. Reinstalled and no boot. Pulled out board, checked work, asked mk1mod what he did. I used smaller hardware, pulled r49, and pulled r50 and installed a jumper. Machine boots but the noise is unbearable. I have the same displays as mk1mod and the same noise issues. Machine is a Nitro Ground Shaker. Any ideas on noise reduction?
Quoted from bflagg:I installed the psu7 tonight and here is how it went. Didn't read this thread and just pulled the old regulator and heatsink and installed the psu7. Reinstalled and no boot. Pulled out board, checked work, asked mk1mod what he did. I used smaller hardware, pulled r49, and pulled r50 and installed a jumper. Machine boots but the noise is unbearable. I have the same displays as mk1mod and the same noise issues. Machine is a Nitro Ground Shaker. Any ideas on noise reduction?
Seems there's an issue then. Daniel (who makes the PSU7) indicated it could be the switching frequency causing the noise, since it's different than the PSU5. My testing was done with PSU5 in Nitro Groundshaker and I didn't notice a noise difference from the sound board.. so if it's very loud and noticeable I'm sure I would have taken notice. Hopefully the cause can be tracked down/remedied.. it'll be cool to have the PSU7 as an upgrade option on the SDBs.
Maybe Daniel can work with one of you guys having the issues. Not sure how much he's checking this thread, so you may need to contact him.. but especially if anyone has tried one of these and has any kind of equipment or technical know-how to check a few things with a scope or multimeter, it may help get to the core of the issue quicker.
Would love to figure it out. Problem is that with regular displays and PSU7 there is no problem. With led displays and LM78H05 there is no problem. However, with led displays AND the PSU7, the noise is horrendous. No one noticed it over the din of TPF but in the house it is unbearable. Some kind of interaction going on there.
This page was printed from https://pinside.com/pinball/forum/topic/lets-get-technical-ballystern-led-display-power-consumption/page/2 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
