Wow, the MPF might be just what I need. Reading up on it now, but it looks like it is a great option for a non-code oriented person like myself. Thanks for sharing that part.
Quoted from BloodyCactus:imo, thats so far beyond the scope of a diy pinball building wiki.
That's fair to say as I really have no way to judge 'overkill' from the software side, but I guess my point is: from my perspective as a mechanical engineer I feel most of the mechanical construction diy stuff is overkill for me personally, but I recognize that many people do not know about or have those specific skills, so it's great to have some reference info in there targeting pinball diy mechanical stuff as opposed to "go search vacuum forming". I personally don't see why a barebones cobbled together flippers/bumpers/scoring coding section is outside the scope of a diy wiki, even if it's simply pseudocode describing how the code works for various items and what steps need to happen to get up and running. But again, maybe im just out of my league in terms of knowledge about what I'm describing
Either way I'm not passionately for or against, and am likely 100% wrong or uninformed on my thoughts, but I'm just addressing the topic to pass some time I think everything is trending the right direction regardless of how the coding section ends up turning out.
Quoted from Purpledrilmonkey:That's fair to say, but I guess my point is: from my perspective as a mechanical engineer I feel most of the mechanical construction diy stuff is overkill for me personally, but I recognize that many people do not know about or have those specific skills, so it's great to have some reference info in there targeting pinball diy mechanical stuff as opposed to "go search vacuum forming".
Either way I'm not passionately for or against, just addressing the topic to pass some time I think everything is trending the right direction regardless of how the coding section ends up turning out.
I agree with your opinion and even if it was a few code samples in different languages to show people what the difference. With the sample codes some basic explanation as even that may help people in which direct they want to go in.
Yeah, it would be nice to have some concrete examples and even just concentrating on MPF when it comes to P-ROC would be fine for beginners.
It would be good to have something for the Arduino folks out there who aren't doing DMD games.
Ultimately having anything there would be great. The rest of it is coming along so well!
MPF works with FAST too, and they're nearly ready to release final hardware, so it's a pretty solid thing to start with I'd think. If you're above that because you're so hardcore then you're probably not reading the programming section of the wiki anyways.
I feel like Aurich just called me hardcore.
I better start making some positive contributions to this community then..
I say stick anything of use up there. I enjoy reading about other peoples techniques on software. Really, it amazes me from all the different ways people achieve the same goals in writing up the rules.
As one who has just the most superficial understanding of C++ and no other languages, I think what I would find the most useful is a "plain English" explanation of the general structure of the code used in pins. As in, "These are the general schemes used, and this is a typical implementation" breaking things up into such categories as "multiplayer, scoring, reading a matrix, firing coils, etc."
I feel like you could then leave the specifics to the designer, but as purpledrillmonkey said above, when you don't know what you don't know...maybe I'm all wet?
Pseudocode would be fine as well.
I would see it as three levels of complexity:
General- What we do
General- How we do the above
Specific- Examples of how
Regardless, I appreciate all the effort being put into this!
ok. knocked out a rough flow idea at work, kinda random brain dump
things like 'put ball onto shooter lane' is a lot more complex (how many times do you try before going into fail mode etc) assumptions in here are for something like a stern machine that has an autoball launch WITH an manual plunger diagnostic menu is glossed over in passing, assumption is hardware interlock takes care of disabling HV stuff ball save timer disabled once game scored 1000 points since starting that ball, or you drain a second time with ballsave on 2 inlanes, 2 outlanes, 3 pops. pops have debounce so they dont trigger themselves in the action of 'popping'. if you see 'now' its in time in milliseconds etc does not go into modes, stacking modes and such. power on ======== (hardware does anything it needs to do) initiate any software driven self tests load/set software defaults load user configuration changes (ie: credits left, freeplay etc) go into attract mode attract mode ============ dazzle lights play sounds is coin door open? yes show diagnostic menu is diagonistc menu enter pressed yes take action is diagnostic menu prev pressed yes go back up option is diagnostic menu next pressed yes advance option if not freeplay? has coin drop switch hit? yes is it freeplay? yes add to credit count display credit count play credit sound go back to top level attract mode no do nothing? if start button pressed? is it on freeplay? no do we have enough credits for player 1? no show more credits screen go back to top level attract mode yes set player count to 1 reduce token count shift to start game mode yes set player count to 1 shift to start game mode is flipper button pressed? display last set of scores on screen for all 4 players go back to top level attract mode start game ========== is coin door open? yes is diagnostic menu displayed? no display active diagnostic menu is diagnostic menu up? yes is diagnostic menu enter pressed yes take action is diagnostic menu prev pressed yes go back up option is diagnostic menu next pressed yes advance option goto start game is current score - ball start score < 1000? yes disable ballsave timer if all balls in ball trough? yes is ball in play no put ball onto shooter lane reset ball saved count to 0 save ball start score yes is ballsave timer < 10 seconds? yes is ball saved count < 1 yes put ball onto shooter lane increment ball saved count goto start game mode no end turn do bonus calc display score shift to next player goto to top of start game no end turn do bonus calc display score shift to next player goto to top of start game is start button pressed? yes is it still player 1 on ball 1? yes is player count less than 4? yes is game on freeplay? yes increment player count zero new players score no do we have enough credits? yes increment player count zero new player score no display credit required screen no cant add players in middle of game is coin switch hit? yes is game on freeplay? no play coin sound (dont show coin graphic in middle of game) increment credit count is shooterlane switch active? yes is autolauncher flag disabled yes set shooterlane sound flag to true no is shooterlane sound flag true yes play ball leaving shooterlane sound display shooterlane animation clear shooterlane flag start ballsave timer has either flipper been held continuously down for 15 seconds? show status screens showing status screen? yes is flipper still held? yes other flipper pressed? yes cycle status screen no close status screen is left flipper button pressed yes trigger left flippe cycle inlane outlane lights to the left is right flipper button pressed yes trigger right flipper cycle inlane outlane lights to the right is left slingshot hit? yes trigger left slingshot solenoid is right slingshot hit? yes trigger right slignshot solenoid is left outlane switch hit? yes light left outlane light add 10 points! are all 4 inlane switch lit? yes add 1000 points clear all inlane lights is special when lit? yes shit the bed is right outlane switch hit? yes light right outlane light add 10 points! are all 4 inlane switch lit? yes add 1000 points clear all inlane lights is special when lit? yes shit the bed is left inlane switch hit? yes light left inlane add 10 points! are all 4 inlane switch lit? yes add 1000 points clear all inlane lights is right inlane switch hit? yes light right inlane add 10 points are all 4 inlane switch lit? yes add 1000 points clear all inlane lights is pop1 hit? yes is now - pop1 hit time > 200ms yes trigger pop1 solenoid save pop1 hit time add 10 points is pop2 hit? yes is now - pop2 hit time > 200ms yes trigger pop2 solenoid save pop2 hit time add 10 points is pop3 hit? yes is now - pop3 hit time > 200ms yes trigger pop3 solenoid save pop3 hit time add 10 points
thats just inlanes and pops, glosses over diagnostic menu etc.
I'd be all for state machines, but things get really hairy if you try stacking modes, giving modes individual timers and stacking them, backing out of one mode while in another etc. (yay for automatic tools and grammer paresr and LR/LALR/LLK parer generators etc).
ooh, the shirts are on sale. I'm pulling the trigger
http://skreened.com/pinballmakers/
Quoted from toyotaboy:ooh, the shirts are on sale
Ordered one today during the sale. I had signed up for an account prior to ordering and got a 15% off code (WELCOME15) to combine with the sale.
I tried opening the DWG file for the playfield layout both in draftsight and edrawing viewer, and it errors out. I went ahead and traced a space shuttle playfield and uploaded a DWG file.
pop bumper drill template added to thingiverse for those wanting to map out parts a little easier.
http://www.thingiverse.com/thing:650229
Ordered a shirt as well.
Swinks. What are the 3 smaller holes near the outer edge of the template for? My EM project doesn't have those and that's the only style I have taken apart right now.
Those are for the special screws that hold the pop bumper bracket to the playfield. https://pinside.com/pinball/forum/topic/vids-guide-to-rebuilding-pop-bumpers
One issue I see, as far as playfields go, is choosing parts.
* Flippers - doesn't matter, bushing size and position are common
* sling mechs -hole patterns are common no matter what you use (but will likely be Stern slings)
* pop bumpers - Hole size common
However...
* trough - Only one I see off the shelf that's available is Stern, which is not the same cutout as a williams
* inline guides - Only one off the shelf available is modern Williams, which I believe is the same as Sega/Data East? I believe early solid state is different
Ideally (going to try to work on this) is to get a generic playfield that works with common off-the-shelf parts. I wonder if it makes more sense to trace a Stern pinball playfield?
Quoted from toyotaboy:One issue I see, as far as playfields go, is choosing parts.
However...
I think as far as template stuff goes it makes sense to think of it in terms of layers or mix-and-match. If you're using a Stern trough, you show the Stern trough and hide the Williams one, but having them both available is best.
for pops I'm using the giant round circle cutout ones, the blue Data East style, I think Alvin G used them. I think they are also in AMH? Happ made them or something maybe? I forget, but I picked these so I only have to route one hole in the PF, less to go wrong for me hand routing stuff
2 return lane guides are readily available:
Williams / Bally - will allow about a 6 3/4 inch spacing between flipper pivot posts
Stern / Sega - will allow about a 7 inch spacing between flipper pivot posts.
Quoted from ecurtz:Is the hole spacing actually different or are the Stern ones just skinnier?
if you are asking about the return lane guides, they are a little skinner. It is the alternative to what stern use on alot of machines with wires ones and then a SS plate at the lead in to the flipper.
thanks for sharing the code with us BC, helps us people with no experience to see samples and which one we should go.
maybe for the pinball makers website, if people with code experience can load up say the same start up program in the different languages so us newbies can see which one to consider.
Quoted from swinks:does anyone want a slingshot template ?
I just uploaded a Williams and a Stern playfield, which includes the holes for the slings.
http://pinballmakers.com/wiki/index.php/Files_Section#CAD_Drawings
This is another template to help as an aid those creating a custom pin that are ahead of me in the build. The slingshot measurements were based off a CFTBL playfield and I have not made a playfield yet to test so use with caution and please let me know if there are any issues though I believe it will be very close.
If you are using the williams / bally return lane guides say from Pinball Life the general dimensions can be found here of where to locate items in reference to the flippers. Using these return lane guides along with other components will mean you will have to space the flipper post holes 6 3/4inch apart for everything to fit across the playfield. Using the Stern / Sega return lane guides may allow you to get 7 inches between flipper posts.
The template will have a 90 degree corner, therefore use the bottom flat piece to be parallel with the bottom of the playfield and like wise for the vertical section to be parallel with the side of the playfield.
I learnt a lot in this process and doubt any 2 games are exactly the same in the way of the overall sling shot plastic size. On measuring a few playfields what is consistent is the dimension from the bottom post hole of the plastic to the switch hole and then to the next switch holes with the kicker arm slot pretty much in the middle those varies 0.5mm. The kicker arm hole appears to be a few degrees kicked so when kicking a ball the ball would kicker higher I am assuming. The dimensions for the remainder of the design is merely my design and doing a practical layout before I tweak to suit game play. Slingshot assemblies will vary in length up the playfield and to the side as will the globe holes but ensure the switch brackets underneath can be mounted.
I hope the info helps and please share with me any tips.
You will notice a overall lower playfield layout to show you general dimensions of parts and for you to consider spacing.
http://www.thingiverse.com/thing:651372
Screenshot1.pnglower playfield dimensions.jpgtop of playfield.jpgbottom of playfield.jpg
As for the programming section, I got a good start on things Friday night with smaller pages. More to come, of course.
I suggest we put things on smaller, more focused pages. Makes things easier to find(or skip over). That, and you can put more detailed information per-page that might be otherwise skipped.
Wow, the programming page is looking great now! Thanks everyone!
As far as putting stuff in smaller subpages, that works where it's cross-referenced - for example, the hardware pages you created work well because I linked to it from both the Construction *and* Programming pages, but I moved the Programming specific stuff out of them to the Programming sections.
Once a section gets really big, moving it to a subpage makes more sense.
Wow there's a lot of accounts being made for the wiki, up to 10 times/hour! Okay, those are spammer accounts. Heh.
Quoted from jwilson:Yeah, it's a huge pain in the ass. I've already mass-deleted over 300
Crap, is there any way of making it harder to sign up for an account? I'm assuming these are spammers looking to use a wiki to turn it into a link farm? Under recent changes today, it's nothing but new accounts.
Quoted from toyotaboy:Crap, is there any way of making it harder to sign up for an account? I'm assuming these are spammers looking to use a wiki to turn it into a link farm? Under recent changes today, it's nothing but new accounts.
I would say shut off new account creation altogether, and make him/her send an email with a specific subject line. A few hoops to jump through should shoo away the overwhelming amount of signups. 99% of the recent changes is account creations.
Quoted from s1500:I would say shut off new account creation altogether, and make him/her send an email with a specific subject line
Or maybe a question about pinball gets PM'd to your pinside account. Surely if you're a pinball builder, you're a pinside member.
Hmm, a pinball specific CAPTCHA? I'll look into it.
You still have to verify your email to edit articles so none of the signups are hurting anything, but it's vandalism none the less.
IFPA has a pretty good idea:
http://www.ifpapinball.com/calendar/submit.php
Go to the very bottom, right above the submit button.
Linolium, where do you get your large format prints? I was thinking I was just going to use Kinkos or something.
I've added a simple question to the sign up process and the flood of spambots has ceased.
Now I'm going to add Linoleum's wiring photo!
I bring my wiring diagrams to Staples and have them print it up 1. Usually costs ~$4 to $8 each depending on the size. Add in $8 for 2'x4' particle board from Lowes and anywhere between $5 to $20 for springs, hardware, and a box of 2" nails.
The Haunted Cruse's switch pin-board was the most expensive so far. Lots of springs and things were used on that one. It was actually 2 harnesses in 1: 8x8 switch matrix + 18 or so wire opto harness. I did the solenoids for it directly on the whitewood so I don't have a board for that. I'll be making a board for the lamp harness eventually.
I posted this on the pinball controllers forum but no one really understood the point of it there. Maybe it could be useful for someone on this thread.
While possibly increasing the number of individual wires for the switch matrix, I'm currently getting some boards fabricated that will allow for running cat5 cables between each board. From a single board you can then split out the cat5 cables to the individual devices (In my custom machine I will be adding another stage of molex connectors so that individual devices can also easily be moved)
The end result is no soldering under the playfield.
For a 16x8 matrix (16 rows, 8 columns) you run 3 cat5 cables to the first breakout board. A jumper setting is used to make the board column 1 and that column is then connected on the board to 2 complete sets of RJ45 connectors (16 wires total). Those 2 RJ45 connectors can be paired with 2 more RJ45 connectors that represent the 16 row wires. Individual wires stem from these directly to the devices so no devices need to be chained together.
3 more RJ45 connectors are then used to allow that first breakout board to be connected to the next board and so on.
Hopefully my boards should arrive in a week, I look forward to wiring/soldering it all up. It means I can just make a massive stack of different length cat5 cables and then (Im planning on making more than 1 machine) I just grab whatever length I need and plug them in. If something needs to move just unplug and grab a different length cable.
Just another different method than pinboards and careful planning.
Note: Oh I was designing this as a panel so ignore the bottom half below the solid line, Ill be using that as the initial connector header that I can then wire into the proc.
RJ45 Breakout Board.pngWanna join the discussion? Please sign in to reply to this topic.
This page was printed from https://pinside.com/pinball/forum/topic/lets-figure-out-the-bare-minimum-costparts-to-build-a-whitewood/page/13 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
