Hello, I need some help with a LW3 project.
Game has Rottendog MPU004 and original boards for the rest.
Problem: Right Pop bumper locks when activated, either by the switch or in coil test mode. Clarification, the coil does not lock when game is turned on like a typical bad transistor. It locks when you press the start button, or when the switch is hit after game has started. Will note that during coil test mode, it will lock on test and release when the test mode is exited back to attract mode. The switch is not stuck on and tests accordingly and passes physical inspection of gap.
History: game was dead when I got it, and it booted after I recapped the power supply. VUK coil locked when turning on game, replaced tip36 on ppb board to fix that. Here is the strange thing first noticed with right bumper. The coil would heat up ONLY when the game had started, not when in attract mode, not locked either just would get hot quickly and burn. This was true even with new coil, diode etc.
Replaced the corresponding transistor on the rottendog board along with one other that was locking on a flasher.
OK after replacing right pop transistor it no longer heats up during game mode, but it now locks only on activation.
It being a rottendog mpu makes this harder to troubleshoot and Im not sure where else to go.. Ive replaced the pop transistor three times with same results.
Anybody have an idea where I can look next? Im not sure what else controls the special coils on the mpu other than the transistor.
Everything else on the game is working like it should now, but this is the last issue I cant figure out.
Thank you for any help or insight!
