Working on a Lethal Weapon 3 that is not booting. The 5v LED and PIA come on and stay on. The Blanking LED never comes on. Power is good at the CPU. Board is very clean with no battery damage.
I pulled the board so I could work on it on my test bench. I tested the 27512 rom and it was good. I burned a Data East test rom and now when it boots the PIA LED comes on and then quickly goes out. Occasionally when I power it up the PIA LED goes on then off quickly and then comes on solid, which according to the documentation for the ROM that means a bad checksum on the ROM. I tried swapping out the CPU with no change. I tested the 6264 RAM and it's good as well. I also checked both the ROM and the CPU socket with my meter and all pins ohm out fine.
Using my logic probe, I'm seeing the following on the 555 timer:
1 - low
2 - high (not pulsing)
3 - low
4 - high
5 - high (not pulsing)
6 - high
7 - low
According to the pinball wiki, pins 2 and 5 should be pulsing and pins 3 and 7 should be high. Based on those readings, it sounds like the 555 is not getting a signal from the PIA at 11B. Is there a good chance that PIA is bad?
Any info would be appreciated. Thanks.
