(Topic ID: 228413)
Lethal Weapon 3 gun wont fire
By tomwitt
6 months ago
  • 5 posts
  • 3 Pinsiders participating
  • Latest reply 4 days ago by dasqer
#1 6 months ago
I have a lethal weapon 3 machine where the gun will not activate the plunger.
I push the start button and try to fire the ball but nothing happens.
Then when i hit the flippers the score starts to run up with each flipper hit, as if the machine thinks there is a ball in play.
I thought that the machine cant tell if the ball is there ready to be fired or has already fired. Maybe the launch lane switch that senses a ball is ready to be fired was bad. I put an reader on it and that switch is working.
The switch test shows that the shooter switch and launch lane switches are working.
When i run an active switch test it shows the switches for the 3 trough switches are active which makes sense... but it also shows "left 4 bank #2" is active. Should that switch be active?
What else can I check?
#2 6 months ago
Dumb question, but did you confirm the coil isn't bad? Could be an issue in the switch matrix.
#3 6 months ago
When I hit start and then start hitting the flippers, the ball will eventually fire, it also fires on startup... so I know it does work, just not triggered by the gun trigger being pulled.
Which coil would I check?
#4 6 months ago
I have somewhat resolved this. One of the side targets was pushed down and making constant contact. Showed as "left 4 bank #2" in the active switch report.
Once I bent that back out to not make contact unless hit the gun now fires.
6 months later
#5 4 days ago
Does anyone know off hand what this coil is or what it can be replaced with.
