Left eject / Saucer coil locks when game is powered on. Flasher 4R will turn on and lock during flasher test. Any flasher tested on the right side relay will also lock the 4R flasher. That flasher will turn off when the relay turns off / switches to the L side.
I have replaced both transistors for the flasher and the saucer, also replaced all 4 7408 chips associated with the coil circuits. All other coils and flashers work as they should. I have also tested the PPB board transistors and diodes, and for good measure swapped out the PPB board with another. Also cut the ground wire to the locked on coil, and then just the flasher locks when the flasher relay is activated.
