I recently purchased my first pinball machine which happens to be LW3. All lights on the play field work fine. The flashers in the back box light and flash correctly. None of the remaining lights in the back box will light up. I literally have zero knowledge of what to look for and I would appreciate some insight. I am normally fairly good at troubleshooting about anything and I am somewhat mechanically inclined. For example, I took the entire play field apart, cleaned it, and put it back together... It STILL works!!!! I say that only because I don't want to scare anyone away because the don't want to help an idiot!!!
Thanks for any help that is available.
On a side note... The center target plastic is broken. I would like to find a replacement.
