(Topic ID: 154252)
Lesson Learned - Gravity Works!!
By WMSpin
  • 23 posts
  • 19 Pinsiders participating
  • Latest reply 1 year ago by WMSpin
    #1 3 years ago
    Leanrned a valueable lesson last night- The Backbox is not a storage shelf. If you put things on top, gravity will laugh at you!
    Enjoy,
    Mike V.
    #2 3 years ago
    Nothing hurt but pride........and yes, gravity is a bitch sometimes.
    #3 3 years ago
    ouch.
    #4 3 years ago
    Good to know, I'll have to find another place to store my bowling balls.
    #5 3 years ago
    Ouch. Good luck cleaning that up, I bet you'll discover crevasses you didn't even know existed on that game
    #6 3 years ago
    I sure hope that wasn't PDI glass
    #7 3 years ago
    Damn.
    I had the backbone glass crash down once and that was about the worst cleanup ever. Doesn't compare to play field cleaning, though. God speed.
    #8 3 years ago
    I'm gonna learn from your mistake on this one,will be adjusting game room after work now.
    Mike
    #9 3 years ago
    Oh boy, sorry to see this.
    #10 3 years ago
    I hope I never go though this. GLWCU. Gravity is a bitch...just ask the Ladies.
    #11 3 years ago
    What was it that you didn't have velcro'd down that took a nose dive?
    #12 3 years ago
    If you really want to have things stacked above backboxes, you could put a small shelf on the wall. I've seen a few folks actually do that. Just remember to leave room for toppers
    #13 3 years ago
    That's a PITA to clean up .... best way I know is find a friend, pull the playfield out, and then both of you lift it out of the cabinet, and rotate upside down and SHAKE .... shake .... shake ....
    That gets most of it ...
    You'll have to pull all the tunnels off underneath too ... those little cubes go everywhere.
    #14 3 years ago
    Wow, what was it that hit the glass hard enough to shatter it? It usually takes an edge impact to set it off, and the edges would be unexposed with the glass installed. I've seen videos of guys suspending a sheet between two wood blocks and hitting the middle with hammers and jumping on it to no avail, but one light edge tap and blamo!
    #15 3 years ago
    Oooooooooohhhhhhh look at all the pretty diamonds
    #16 3 years ago
    I was "smart" enough to put a wireless rock speaker up there for temporary storage for the winter. Pins are in the garage and TOTAN is the first game by the door that leads in to the house so its really easy access. So long story short, a big rock went through the glass.
    Update - New glass is on the way and cleanup seems to have gone well. Anyone have any suggestions on what to use to get the powder residue off the ramps and playfield without grinding it in further. I used a shopvac and a compressor with an air nozzle attachment. I'm sure I didn't get it all and will be finding some hidden gems for a long, long time
    Quoted from DanQverymuch:Wow, what was it that hit the glass hard enough to shatter it? It usually takes an edge impact to set it off, and the edges would be unexposed with the glass installed. I've seen videos of guys suspending a sheet between two wood blocks and hitting the middle with hammers and jumping on it to no avail, but one light edge tap and blamo!
    #17 3 years ago
    Quoted from WMSpin:
    Lay the pieces out on the floor and jigsaw them together. You might have all the pieces, so no worries
    Sorry, that stinks.
    faz
    #18 3 years ago
    Quoted from WMSpin:
    I'd probably just use several microfiber towels, throwing them away occasionally to avoid accumulating too much in the fibers.
    #19 3 years ago
    You can also roll tape backwards around your hand sticky side out and go over everything lightly. You won't get it all but you will get some.
    #20 3 years ago
    Been there.
    #21 3 years ago
    I've never been there pf-glass wise, but from cleaning drywall dust out of equipment, I second the tape-tack method, for places you have access to.
    Otherwise a damp microfiber towel could work for the tighter areas. Wedge the towel into places and the liquid tension within the fibers should pull whatever it contacts with.
    Another method I have found especially useful for cleaning fragile models with intricate details and recessed line patterns, etc, is to use children's "toy slime". But viscosity is key: there used to be something called "Gak" that was thinner than silly putty, but thicker than toy ecto-plasm... that was perfect but I don't know what's available now. Anyway that stuff would gently settle, pool, and form-fit over every surface, but then pull up in one piece with every loose bit of dust or crud attached to it. So it made a super effective yet gentle physical cleaner with no scrubbing or abrasion. It did not normally leave an offensive residue but obviously test it first.
    I imagine other inaccessible glass bits will get shaken loose with the natural shocks and vibrations of the game, so check periodically for a while.
    #22 3 years ago
    Quoted from goingincirclez:
    Yes, you're going to be finding yet more little bits of glass and dust for weeks ... it's unfortunately just part of the process ... basically take the glass off and re-vacuum weekly until it largely stops filtering out.
    1 year later
    #23 1 year ago
    Been well over a year and I'm still pulling glass of the TOTAN - I don't know where these broken pieces hide, but I'm guessing it's the same place my socks go when I put them in the dryer.
    MV
    $ 29.50
    The MOD Couple
    $ 69.99
    $ 109.99
    $ 125.00
    Sparky Pinball
    Meph's Mods
    $ 229.99
    $ 29.99
    $ 14.95
    $ 9.99
    $ 34.95
    Hookedonpinball.com
    $ 84.95
    $ 499.99
    Great American Pinball
    Sparky Pinball
    Bright Lights Pinball
    Apparel - Unisex
    Pinball Wheezer
    $ 9.95
    $ 269.00
    Displays
    Boston Pinball Company
    $ 175.00
    Professor Pinball
    $ 29.99
    Metal-Mods
    $ 22.00
