Getting better at this game is a blast!
Did 3 raids now and still don't know how exactly they're set up but I know there's a red arrow to the boat now
Starting to actually have strategy around which boss I fight and when.
Broke 80 million today.
Some strats:
1. Fight Jörmungandr when you need to charge the hammer anyways.
2. If you get ship locks done you can use draugr to go for many ship ramp shots if the plunger letting the ball drain. If you don't have shiplock I try to get lock activated and charge Thors hammer. Nice to play dangerously with ball save and multi-ball. I try to get the ship ramp for points but draugr is not the best for points anyways.
3. Do lots of combos. Left ramp, middle ramp and repeat. Like to do left ramp, middle ramp, thors spinner loop, and then ship ramp too.
4. Seems very lucrative to get as many shots on boss as you can before using thors hammer or valkyrie. Some people mentioned not being able to use valk or hammer when draining, but works for me.
5. If you got valk and hammer and draugr is done start banshee so you can use hammer then use the valk on Dearg Due next in line. Remember hammer fires first!
Working on:
1. Inner and out loops except Thors spinner seem very tough to hit. Also, if I hit it well it feels like a punishment with how fast the ball is flying. Drained a lot from outer loops speed
2. Still cannot consistently hit the event activation scoop, under flipper shot, or shooter lane shot. Back hand from left is usually too wide but it's the one I've made the most, right flipper to under flipper have not hit once yet, right flipper to scoop I've done once, but missing slightly I've drained hard off of, and shot to shooter lane I've only got with luck.
Complaint:
One complaint is the scoop shoots the ball to the flipper on in a very wide arch. Usually hits center flipper but occasionally hits the tip of the flipper for less then ideal effect. Should I adjust or is this good?
