Quoted from luvthatapex2:Welcome to the clan! The RAID letters should all be crystal blue and cycle as you flip the flippers. (R > A > I > D) They are never white, yellow, etc so you have a connection problem or led board issue.
They were white on old code, right? This was running May, 2022 if I recall, and they were white until I updated the code...
That video was helpful, thanks!
Quoted from Dwboca:This happened on mine after long play. It can get hot under the playfield. I installed pinmonk coil fans. Haven't had it happens since, but were having a tournament in a few weeks. That'll be the test
I think that might have been it - I went to check it out first thing this morning and it's all normal now. The light test worked fine. I have Pinmonks fans on a few other games so will probably buy them for this too, especially if it happens again.
However now I have another question. I went through the individual light tests and noticed I have no lights for the two slings (the spots aren't installed, not that I think I need them...). Looking at pictures, I think they're supposed to be there, right? Mine was manufactured in March, 2022 but had only 71 plays when I bought it - it was sitting in a box until recently.
I also noticed that the ship only lights white, as does the spotlight that shines by the spinner. Is that normal? I reseated the connectors on board 10 and it has the same behavior, although the data wires that go to the board are pretty tight. That said, nothing else the board controls seems to have the issue so maybe it's only supposed to be white?
On the bright side, I made it to Valhalla for the first time. Got destroyed by Odin, but at least I made it!
Update: Played for about 30 minutes today and the RAID lights changed again. Finished the game, rebooted, and played another 30-45 minutes without issue. Not sure it's heat related at this point but will continue to watch it.
