two questions, I was looking at replacing the incandescent bulbs in a funhouse. There is a mirror with all these incandescent bulbs with colored covers around them. is there something similar in the led world that would look similar? I'd keep them, but I already have enough to keep up with as is without having to change burned out bulbs.
also I replaced all the leg levelers with the same size 3" shaft, being somewhat new to all this I know some games are supposed to have less of a slope then others. So I consulted the manual, It said the slope should be btwn 6 & 7 degrees. So Figuring 6.5 would be a good compromise. I had to raise the back legs all the way up to where there was no thread left on top. It's still only at 6.25 degrees?!
I found some leveler on twisted quarter that are 4.5" not sure if I should go for those?
