Had to remove the legs to haul / transport machine home. Went to put legs back on and found the attached issue. Best way to repair??? Could use some advice. Do I just add a small bracket to secure two split sides or remove broken piece entirely and replace? Want it secure more than anything but would like to do it "correctly" so as not to cause further problems.
Close encounters Gottleib machine. Picked it up cheap and would like to use for home use primarily.
Any advice is appreciated. Pic of crack is attached.
thanks
