(Topic ID: 113149)
Leg bolt brackets don't fit?
By sake
  • 17 posts
  • 11 Pinsiders participating
  • Latest reply 4 years ago by johnwartjr
#1 4 years ago
So i bought 4 leg bolt brackets for my restored HS2 cabinet (which originally have the small leg bolt plates).
I found out that they don't fit well, too much space between bracket and corner joint. Besides that the outside plates aren't correctly curved.
What do you suggest?
#2 4 years ago
Return them and get the correct ones sake. If you do not want to do that make a spacer/s to pack the void and use them.
#3 4 years ago
Thanks for your reaction wayner. I didn't knew there are several types?
These one should fit from mid-80s to the present according to the suppliers website.
#4 4 years ago
You could fill the gap with wide washers. I wouldn't worry about the sides laying perfectly flat. I drilled out the side holes to fit big #12 screws. They are REALLY solid now.
#5 4 years ago
I'd just put a wood slice between the plate and the gusset.
#6 4 years ago
Assuming your cabinet corners are square, return these and tell the supplier to provide ones that have proper bends; the legs on these look to be a slight bit less than 45 degrees to the body of the plate.
#7 4 years ago
I think the plates are fine, just that the gussets are made of scrap wood that can vary in size.
#8 4 years ago
These are the ones I use on that vintage of machine:
http://www.pinballlife.com/index.php?p=product&id=858
#9 4 years ago
Legs should be 45 degrees but mine are 40 i think.
Found out that this type of bracket does fit on one of Christophers HEP Getaway cabinet. So it could be indeed that multiple sizes of gussets were used.
So i think two options:
a wood slice to fill up the space and use these 'new type' brackets;
buy improved version 'old style' brackets:
i don't prefer corner seperation on my restored cabinet
#10 4 years ago
Can you take the existing brackets you bought and bend them better in a vise?
#11 4 years ago
Yes. I've had a few I've had to do this too.
Quoted from KenLayton:
#12 4 years ago
im thinking they will pull in quite a bit if you just do the bolts up?
#13 4 years ago
I don't think the bolts will pull one of these flat. The metal is pretty thick.
I don't think that HS2 is an original cabinet. It looks like an aftermarket one? I know on the HS2/CFTBL era, the new brackets often hit the power box when installed.
#14 4 years ago
Did someone chrome the prop bar?
#15 4 years ago
very astute of you
#16 4 years ago
I'm just in disbelief.... that someone would take the time to mod the prop bar....
Quoted from j_m_:
very astute of you
#17 4 years ago
Quoted from jalpert:
That's not the only non-stock thing in that picture
People mod everything!
$ 175.00
Professor Pinball
