(Topic ID: 217874)
Left Slingshot Switch help
By Guzz4851
1 year ago
  • 7 posts
  • 3 Pinsiders participating
  • Latest reply 1 year ago by zacaj
    #1 1 year ago
    Having issues with my left slingshot switches on AC/DC.
    Noticed during the game the left sling would stop working. Did the simple stuff, cleaned the switch ends, regapped them but that didn’t work. So I started moving the wires underneath and went into switch test and realized the switch was intermittent. If I slightly bent the tabs of the switch it would register, then move the wires again and it wouldn’t register. So I figured it was some sort of loose/ bad connection. I reflowed all solder on both switches and tabs. It worked great in switch test even when jiggling the wires underneath. I began to play a game and after a little bit of use it stopped working again.
    Is it possible that one of the leaf switches is bad? I wouldn’t think it would just stop working. Any ideas what to try next? Or am I just better off buying two new leaf switches? Thanks.
    #2 1 year ago
    How did you clean them? Does the diode look ok?
    #3 1 year ago
    Qtip and alcohol. Could the diode be a problem? It looks ok, but I could try and replace it if that could be the cause...is that possible?
    #4 1 year ago
    Quoted from Guzz4851:
    Maybe it, or its leads, are cracked internally or something. Can't hurt to replace to rule it out
    #5 1 year ago
    Thanks. I’ll try the diode first and if not I’ll be ordering a leaf switch. Thanks much for the help!
    #6 1 year ago
    or you can just test that diode with a MM and see if it is shorted/faulty..just remember to remove the green wire it slides right off
    #7 1 year ago
    Quoted from Cycloneman:
    Since it's intermittent I wouldn't trust a test. Likely to give you good results at that moment as not
    Metal-Mods
    Pinball Art Prints
    $ 29.99
    $ 86.95
    $ 18.99
    $ 96.95
    $ 7.95
    Various Novelties
    Pinball Wheezer
    Yorktown Parts and Equip
    $ 69.99
    $ 59.95
    pinballmod
    $ 199.99
    $ 24.00
    Metal-Mods
    $ 62.95
    Medisinyl Mods
    $ 10,500.00
    Great American Pinball
    $ 142.00
    nvram.weebly.com
    $ 18.95
    Lighting - Backbox
    $ 29.99
    $ 149.99
    $ 69.95
    pinballmod
    $ 369.00
