(Topic ID: 274715)
Left Slingshot Intermittent and Sound Cuts Out
By PinballGurus
#1 3 years ago
Having an issue with an intermittent left sling that cuts out the sound. Looks like the board has been worked on before on that transistor and not a very good job. Assuming it’s a CSJ, or bad transistor, diode, etc. but what’s up with the sound cutting out when I ground the transistor? Ideas appreciated...
18171501-586F-4767-B9BF-CA3F5F9B48A2 (resized).png18171501-586F-4767-B9BF-CA3F5F9B48A2 (resized).png41FFC41E-0DF6-4DA5-BC5F-163ECAD6A0EE (resized).png41FFC41E-0DF6-4DA5-BC5F-163ECAD6A0EE (resized).png5BA87B75-6087-461C-BFCE-9FD9C960CF83 (resized).jpeg5BA87B75-6087-461C-BFCE-9FD9C960CF83 (resized).jpeg5E685793-56B1-4DD6-9944-6917CBF00EF4 (resized).jpeg5E685793-56B1-4DD6-9944-6917CBF00EF4 (resized).jpegA6D83F4A-F273-4C7C-8CFC-E168EBAFC8AF (resized).jpegA6D83F4A-F273-4C7C-8CFC-E168EBAFC8AF (resized).jpeg
#2 3 years ago
Bad diode on the sling coil?
#3 3 years ago
Quoted from slochar:
I checked the sling diodes initially and they tested good but I’ll try again after I fix this repair and clean the board and report back. Thanks!
#4 3 years ago
I was thinking maybe the carbon buildup on the board could be an issue so I pulled the board today and decided to try and clean up the old repair. I’ll change the coil diode if that doesn’t fix it.
#5 3 years ago
So I decided to just replace the coil diode and that worked a short time, and seemed to fix the sound issue so now I’ve decided to go ahead and repair the board and swap out the transistor. Any other ideas if that doesn’t work?
#6 3 years ago
Turned out to be a bad diode and bad transistor.
$ 32.00
$ 18.95
$ 44.99
Pinball Shark
$ 27.95
$ 95.00
Pinball Mod Co.
This page was printed from https://pinside.com/pinball/forum/topic/left-slingshot-intermittent-and-sound-cuts-out and we tried optimising it for printing. Some page elements may have been deliberately hidden.
