Playing a game and left flipper quit. Cleaned flipper switch and flipper worked for one more flip then quit again. Power (70VDC) is present at all three lugs. Coil and Coil diodes are good. Even swapped flipper coils. Problem stays on left side. Cleaned EOS switch with no change. Continuity is good through EOS.
Here's the (will not fire.....at all) strange part. Even though power is present at the coil lugs, I can't even get the coil to fire by shorting the center lug to ground. Right flipper fires using this test but left flipper won't.
Here's what we know. Coil is good. Coil diodes are good. 2A fuse at f6 is good(obviously since there is voltage present). Voltage at coil lugs is good. EOS is good. Have not tested relay K1 or any of its controlling logic yet. Since that relay turns on ground for both flippers and the right one works......Possible that one side is not connected to ground, but I don't understand why that would matter when directly shorting center coil lug to ground.
Any ideas?
