Might be a little low. Put a straight edge on it and check. Often there will be a straight path from the inlane to the end of the flipper rubber. Also check for guide holes at the tip of the flippers, some games have them.
For Bally Williams games of that era, my understanding is that you put a toothpick into the hole in the playfield along the bottom of the flipper, remove the rubber, the flipper bat should be sitting on it when at rest.
Can’t see the hole from you pic, but looks good to the naked eye.
Quoted from ryanwanger:Bally Williams games of that era, my understanding is that you put a toothpick into the hole in the playfield along the bottom of the flipper, remove the rubber, the flipper bat should be sitting on it when at rest.
You can see a couple photos of this at http://homepinballrepair.com/index.php/pinball-flipper-rebuilding-how-to-fix-and-replace/
near item 16: "16) Swing the bat into the desired position. If there are small markers in the playfield, the bat should either point at the marker, or rest on it. If the alignment point is below the flipper, insert a toothpick into the marker and set the bat against the toothpick (without the rubber). If no markers are present, set the bat parallel to the wire on the playfield."
This page was printed from https://pinside.com/pinball/forum/topic/left-flipper-level and we tried optimising it for printing. Some page elements may have been deliberately hidden.
