With how much everyone here likes to use blindingly bright leds in their games and use the "they give off no heat" reason. Here are some facts about that. The following pics are of an incandescent bulb, a cointaker 2-led cool white frosted bulb (received yesterday), cointaker 1-led cool white frosted (currently not offered, from my old stock), and an old ablaze LED from pinball life (old stock). The pic with 3 bulbs is the inc on top, the 2 led in the middle and the 1 led on the bottom. The ablaze was out of frame. These were all put into BoP and left in attract mode for 5 minutes prior to the photos being taken.
As can be seen the incandescent is running about 217 degrees. around the bulb, not reading the filament. The filament was off the scale over 500 but a very tiny hot spot. The glass was giving a uniform reading around 220.
The center bulb is the 2led cointaker bulb its reading 140, much cooler than incandescent which is good.
The lower bulb is the 1led cointaker bulb, its reading only 111 degrees.
there is almost a 30 degree increase in temp just from adding a second LED to the package.
Lastly there is a pic of the ablaze bulb, its cool white and way dimmer than the other 2. These are what was in the game already, although I put this one in new from my stock to make the comparisons even. This bulb was produced probably 4 years ago. It is also not a super bright and is only reading 71 degrees the background temperature of the game is indistinguishable.
Can people now at least stop saying that they use LEDs to avoid the heat so as not to damage the plastics? The LED's shown are not superbrights these run cooler than those and while cooler than incandescent as you make them brighter they lose that benefit quickly.
This is not a call to action against LED's at all. I'm changing the ones in my BoP and Pinbot right now to the cointaker 1 and 2 LEDs.
