Quoted from swampfire:But so is
But so is Blitz 100 Grand…
Any recommendations? I’ll stand by my statement that Klasse All-in-One is less abrasive than Novus 2, and it works great on CC’ed playfields.
yeah any car product is adequate for a pinball machine coated with the exact same product cars are.
Not sure why people insist on using the wrong chemical (novus).
Klasse is a polishing with a sealer.
The sealer on it might act like a wax. The point of sealer is to create a barrier so grime, bird droppings, dust, brake dust, etx do not attach to the paint.
I would apply it mechanically with a machine and not by hand (because nothing polish better than a machine if you truly want to keep your clearcoat scratch free and in good shape)
Do not fall for the marketing “it does not remove clear coat” that is just taunting the fact that it will not melt or permanently remove it, but klasse is a polisher.
It is a polishing cream with a sealer, that is what 2-1.
It is product designed for the people that want to polish their car every week. The sealer will not last very long and the polishing compound in it is very fine, therefore it will remove very little clear but so does any polishing cream if you use the proper pad.
It might be very efficient for Pinball!
I would just apply it with a machine
Not sure how long it lasts but if it works then great.
If it containe silicones it might be problematic if the pf needs to be recoated again.
I will personally stick to wax as it is easy to remove with alcohol, whereas a sealer is chemically binding until it wear off with time/eleMents/friction. The sealer in klauss might not be like the modern polymeric sealers so it might be removable with cleaning.
In the car world newer coatings exists that are based off some harsh chemicals that bond and cure as a thin film over the clear making it hydrophobic for 6-12 months.
Klasse is not that
