(Topic ID: 283506)
Led Zeppelin Owners Thread
By Hayfarmer
1 year ago
  • 7,793 posts
  • 416 Pinsiders participating
  • Latest reply 3 hours ago by PoMC
  • Topic is favorited by 137 Pinsiders
Topic poll
“Led Zeppelin Owners Thread ”
  • Pro 61 votes
    20%
  • Premium 127 votes
    42%
  • L.E. 114 votes
    38%
(302 votes)
11 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 7,793 posts in this topic. You are on page 143 of 156.
#7101 4 months ago
Quoted from Chalkey:
A customer just told me they started "top of the charts" by holding in the flipper buttons. After completing their game they played a normal game and it had a perpetual ball save. He said ball save was not lit, but ball 1 never ended. He restarted the game after 10 minutes. Anybody seen this?
I believe I read someone post this a long time ago. My guess is old code.
#7102 4 months ago
It's the latest with Insider Connect working.
#7103 4 months ago
To be more specific, I "think" I ended the top of the charts mode, but it went into a regular game. The timer on the screen definitely stopped showing up. Although I feel I might have gotten free ball saves when it was still in the mode. Premium 1.12 code, insider working great.
#7104 4 months ago
Is the placement of this piece normal?
It's at the ball entrance of the playfield.
It now rests at the ball guide.
#7105 4 months ago
Quoted from Pinballnewb01:
No it should hang freely.
#7106 4 months ago
What are the best music settings for the stock speakers on the Pro and Prem?
#7107 4 months ago
Oh man I just put some under cabinet lighting on today and wow. Looks awesome!
#7108 4 months ago
I think I just made the biggest mistake by having the playfield waxed for first time after about 750 games. Before I was able to control the shots and cycle through songs somewhat steadily but now it’s crazy fast and I’m lucky to get halfway through a song. I’m playing very similar to when I first got the game where I was struggling to crack 25m. Also, is it common for there to be more spin on the ball after a good waxing?
#7109 4 months ago
I literally just had this happen yesterday. I also had to just shut it off. Weird
#7110 4 months ago
Hmm interesting I
Quoted from briyau15:
It's normal. It will wear off pretty quickly.
#7111 4 months ago
I’m running 1.12 and have been having an issue with EM not holding the ball captive after the stage comes back up. It’s dropping the ball within a couple seconds and awarding me big points for “hitting” the ball. Used to hold the ball captive until I actually hit it before this update. Around the same time that I updated I also adjusted the playfield angle to be steeper, and I thought that was causing it. I’ve tried the playfield at various angles with no luck. Saw some earlier posts in this thread where some were having the same issue, but I didn’t see any resolution yet. Are others still having this issue with the 1.12 code?
#7112 4 months ago
Quoted from JeepSnob:
Hmm...1.12 (I think that's the latest...) was created to fix that issue (it was broken in the code before that). I would double check that you are on the newest code. If so, it sounds like there might be an issue with the opto. Check to make sure all the connections to them are good, clean them, make sure nothing is blocking them, make sure they are aligned, and make sure there aren't any bad solder joints. Good luck!
#7113 4 months ago
Having an issue with washer on the end of the shooter rod is hitting the auto plunger. I checked the shooter and the auto plunger and I don't see an adjustment here. Any hints or solutions out there?
#7114 4 months ago
I had the same issue a couple of weeks ago.
But I have not found a direct adjustment possibility. Therefore I lowered the shooter rod assembly with loosing the screws from internal of the cabinet, pushed the assembly as low as possible by using it's tolerance and fixed it with the screws again.
#7115 4 months ago
What a awesome pin
I ordered a alternate translite from eBay because the Premium artwork is so redundant.
My GNR LE is getting jealous because of all the attention LZ is getting
#7116 4 months ago
Quoted from dergroover:
I have had this issue also. I checked mine against my Turtles and everything looks the same but it is still hitting. I will check out this fix.
#7117 4 months ago
Quoted from rusty_dagger:
I fixed it for now. Loosened internal shooter plate screws, pulled rod down and retightened. Then stuck a rubber button on the plate for the autoplunger where the mechanism rests. Let's see if it stays fixed. Shooter and auto plunger both work atm.
#7118 4 months ago
Quoted from glpinball:
That's the same way I have done it. Rubber instead was not needed on my LZ.
#7119 4 months ago
Quoted from Jediturtle:
Problem solved. It was an ID-Ten-T error. Apparently I downloaded the 1.12 code, put it on the flash drive, and got distracted a few weeks ago when I was updating my pins. Didn’t actually install it. Good news is that the optos are good! Thanks for the suggestions.
#7120 4 months ago
Quoted from greeneye:
What a awesome pin
It’s funny, that’s one of the things I liked about the premium, all the black and white made the table absolutely pop!
#7121 4 months ago
Quoted from Hipponotic:
I agree completely. I love the black and white artwork. Makes it stand out among the other colorful games everywhere. I also really really like the pro cabinet and artwork. I would've bought a premium as I like the artwork better, but an LE came up in my area for MSRP in July and I jumped on it as I figured it would maybe hold it's value just a bit more.
#7122 4 months ago
I like the blue color on the LE but also love the very clean look of my Premium and therefore don't want to change to those, admittedly very cool, alternate translites.
#7123 4 months ago
Quoted from shlt_thunder:
I have a premium if you like that artwork that much better…
#7124 4 months ago
Ok. I ordered my top 4 powder choice samples. Let me know what you all think.
01ABF5B2-DDF9-4FEA-AFC4-3720D3D5E1AC (resized).jpeg33BB6BEE-DA21-4EAE-8508-44035FD1D9A0 (resized).jpeg52BDA968-133A-4AD8-AF7A-A93AA100A1D1 (resized).jpeg64F79C7D-F9D8-4832-9F83-8D5C055EBB12 (resized).jpeg
#7125 4 months ago
Quoted from thekaiser82:
I like 2 or 3, something in the middle.
#7126 4 months ago
Quoted from BrianJ1337:
same.either will look nice.
#7127 4 months ago
In the light shredded black. I think vein will be a nice touch! I think this is the style on JJP GnR. Seems more durable to damage.
#7128 4 months ago
Quoted from thekaiser82:Ok. I ordered my top 4 powder choice samples. Let me know what you all think.
If I was going to do this I would be giving red a good look with either a black or metallic fleck in it.
#7129 4 months ago
Before I ordered samples #2 black frost was going to be my choice. I think it still is now that I have the samples.
#7130 4 months ago
Quoted from Psw757:
I was worried red would clash with the orange on the armor.
#7131 4 months ago
I did silver artery on my mando, came out real nice
#7132 4 months ago
Whatever the color of the LED Zepp font on side is what I meant.
Premium needs a little color to make it pop.
#7133 4 months ago
Quoted from Psw757:
Ahh. Gotcha!
#7134 4 months ago
Quoted from Lermods:
Do you have a pic to share. Would love to see it.
#7135 4 months ago
3,2,1,4 is my preference. I have something very much like #3 on my Met premium and it looks and FEELS fantastic.
#7136 4 months ago
Quoted from Psw757:
Prismatic's Illusion Tangerine Twist is a good match for the Led Zeppelin letters on the cabinet.
#7137 4 months ago
Sure...
PXL_20211117_000033270 (resized).jpgPXL_20211117_000146233 (resized).jpgPXL_20211117_000153403 (resized).jpgPXL_20211117_000218876 (resized).jpg
#7138 4 months ago
Quoted from andre060:
That looks great
#7139 4 months ago
That's just the most perfect but subtle amount of "pop" for that theme. Love it.
#7140 4 months ago
Anything to fill in the blank around the reader?
#7141 4 months ago
Just checking in ,I really miss this game since we sold it to get a METprem .I will be back .Carry on
#7142 4 months ago
I have a LZ pro question. If the ball plunges from the shooter lane and hits the dead end shot, is it supposed to start a super Mode and add multiplier time? I feel like mine didn't award this when i first had the game, now it does. I love it because it gives me 'free' super modes and extra long playfield multiplier time, but wasn't sure if it was right.
#7143 4 months ago
Cousin gave me his old black light poster tonight. I had the same one when I was kid but apparently he kept his.
#7144 4 months ago
That’s awesome! I have some led zep art in my game room too.
#7145 4 months ago
Zep show and tell?
How about these cool bootleg coke mirrors a friend of mine won as a teenager at a Long Island fair. He contributed them to my game room!
#7146 4 months ago
#7147 4 months ago
i guess you cant see my wall of paraphernalia
#7148 4 months ago
Have a few more odds and ends but nothing really special. My pin is definitely my most expensive Zep item! But I will say the black light poster my cousin gave me is probably one of my favorite items next to my pin!
#7149 4 months ago
Quoted from CrazyLevi:
Zep show and tell?
I don't see any Coca Cola symbols on those signs.... oh wait...
12
#7150 4 months ago
Just joined today.
Amherst, NY
$ 99.00
PinballReplacementParts
$ 400.00
PinWoofer
$ 599.95
Pin Stadium Pinball Mods
