(Topic ID: 318420)
Led Zep won't boot. Tried many things. Ideas appreciated!
By VALIS666
1 year ago
  • 16 posts
  • 7 Pinsiders participating
  • Latest reply 1 year ago by Sawyer23
    #1 1 year ago
    Sorry to write a novel here, but these details could come in handy to help diagnose a problem that so far has not had an obvious solution.
    Earlier in the year my Led Zep LE sometimes wouldn't boot code. Maybe 1 of every 5 attempts failed, but it would always boot up next try. The success rate became more and more rare until it got to the point where maybe 1 in 10 tries would boot, then 1 in 20, etc. Also, it froze in attract mode a few times when I was away from the machine. On the Spike 2 CPU I always get all the voltage lights (48, 3.3, 5, 12) but never VA or VNB unless the boot was successful. Power is being distributed successfully around the cabinet and playfield to all boards as indicated by their red lights, but the CPU/code doesn't get engaged.
    The first step with the no VA/VNB problem is to burn a new SD card with the specific game code and try that, or try an SD card from a working Spike 2 game to see if the non-working game would at least boot. I've tried both, hasn't made a difference. I've tried SD cards from a bunch of my other working Spike 2s, so a defective SD card clearly isn't it.
    At this point I emailed Stern (no more phone support, it seems), they said it's likely a bad CPU board and to get another from my distributor. One month and $400 later, putting a different CPU board into Zep hasn't made a difference...
    EXCEPT one time when I reseated everything on the power distribution board, turned it on and it booted up! I then played three games, shut it off, and went to sleep late that night happy that my Zep was more or less fixed, there's just a flaky connection somewhere that I could root out. But it didn't boot the next day or any time since then in at least 50 more power ups. I have tried a long list of things since then, including:
    - Different SD cards
    - Reseating *everything, everywhere* (especially PDB) 10 times over
    - Wiggling PDB, CPU, cabinet, and playfield board connections while powered up to see if I could trigger VA/VNB
    - Examining wires for frays, boards for bent pins, molexes for loose wires, and anywhere there might be a potential for a short
    - Taking everything off VA (voltage audio) and VNB (voltage node bus) one connection at a time while powered down and rebooting to see if that would trigger the CPU
    - Swapping a working PDB to CPU wire harness from one of my other Spike 2 games. This was my last shot ace in the hole and it didn't work. The same wire harness worked fine when I put it back in its original game (Munsters)
    Pretty stumped at this point. Remaining ideas are I somehow got a bad replacement CPU board (or fried it) but this seems unlikely since the new CPU board wouldn't boot at first (roughly 5x), then it did *once* and played a few games, but hasn't since in about 50 tries.
    Or maybe (probably?) the power distribution board is bad. I have another one incoming. Serial number ending in 00A instead of 00, but I don't think that matters as far as I can tell. Obviously the next step before that new board comes in is to swap a PDB from one of my working Spike 2s into the Zep, but could anything in the Zep (like the power supply) be harming the PDB and then I'd be down two power distribution boards?
    Thank you for any suggestions or ideas!
    #2 1 year ago
    Take it back to your Distro and tell him give it back when it works.You have had nothing but issues from what I have read.
    You should be enjoying this great machine and Thats no help but it is what I would try next.
    #3 1 year ago
    Quoted from VALIS666:
    Did you reseat the power cord on the back of the head?
    Also, do you have a multimeter? If so, measure the output from the power supply to make sure it's not under 48v. If it is, you can turn it up with the little potentiometer.
    #4 1 year ago
    Any add on mods that would draw power on start up?
    #5 1 year ago
    Quoted from Jamesays:
    Thanks. It's about 6 months out of warranty right now so both the distro and Stern are helping, but it's hardly a top priority for either. I don't want to push too hard until it's really necessary.
    Quoted from PinMonk:
    Thanks Vic, I was hoping you'd see this, you have a good knowledge of Spike 2. I've reseated the power cord many times, pretty much any time I'm reseating anything on the PDB. Would the 48v on the CPU light up if it was getting significantly +/- 48v? But I'll measure it like you suggest.
    Quoted from titanpenguin:
    Nope, no power-drawing mods, just a couple cosmetic things like rubbers, translite.
    #6 1 year ago
    Yeah, I think the light will still light up. I don't know what the criteria is, but I think it pretty much is just saying the 48v line has power. I don't think it's super-sensitive to the precise amount of power on the 48v line or how much under there has to be before the light goes off.
    You could also swap the entire power supply from another Spike Prem/LE that works and see if the problem goes away. That would cover dirty power or other power supply defects that may not be obvious. It's super easy to take the power supply off one and put it on the other, so wouldn't be a bad idea.
    #7 1 year ago
    Update. Didn't get a chance to troubleshoot this week with a dog on death's door who we put down yesterday (RIP, Ruby). Was also waiting for the new power distribution board to come in.
    First thing I did was to install that. Not the most efficient idea given it was a bit of a pain in the ass. What I should have done first was this like PinMonk suggested:
    Mind you that is coming out of the new PDB, but I assume the old one was fine anyway.
    Ready to pack everything up and give up again in frustration, I remembered an idea I had during the week, put a USB in with the latest LZLE code (1.15) even though the SD card in the machine already had 1.15. It worked! Booted for the first time in the last 100 tries, installs the same code over the old one, verifies, and worked again on reboot. Awesome. I'm gonna play it 100 times tonight if it keeps working.
    This may not be the end of the story, though, as I mentioned in the first post I previously somehow got it to boot twice in a row, played a few games, but it never booted again until today.
    Any idea at all what's going on here? This pinball was already not booting with its original factory SD (running 1.14) or SDs from my other working Spike 2 games, so it's just hard to understand what the problem is and what to look for in the future if it doesn't boot again.
    #8 1 year ago
    Do you keep trying crappy Stern stock SD cards? Try a brand new class 10 Sandisk ultra (bought from brick and mortar best buy,target, etc ONLY- counterfeits are rampant online for sandisk, even at Amazon).
    #9 1 year ago
    Can't help with the issue you are having but wanted to express my sympathies for your dog Ruby. Probably one of the most difficult things to do in life....
    #10 1 year ago
    Yep, Sandisk ultra class 10 from Walmart, albeit 32gb rather than 16 or 8 since that's about all you can find at brick & mortar. No other Stern cheapo SD cards from other working Spike 2 games work in my Led Zep, so it's puzzling. Even though they're crappy cards, if they work in another Spike 2 they should work in the Zep. Which is the first thing Stern tech support suggested to me when I wrote a month ago -- try a SD from another game. Second thing they suggested: buy a new Spike 2 CPU board... somehow... but not through us since we don't have any. Which I did finally, and bzzt.
    Quoted from CubeSnake:
    Thank you, I appreciate it.
    #11 1 year ago
    Try taking the SD card out and carefully shooting some compressed air in the SD slot. Maybe some bit of debris is partially blocking one of the pin contacts causing weird behavior with the card installed. Also, I don't know how you could shoot an image in that narrow slot to see, but maybe a pin contact is bent in there.
    3 months later
    #12 1 year ago
    Hey @valis666, I seem to be having a similar issue with my JP right now.
    Was a new CPU what finally fixed it for you? Mine currently is booting pretty frequently, but will sometimes take up to 20-40 seconds before the screen comes on.
    #13 1 year ago
    Hi @sawyer23. Nope, nothing really fixed it for me, sometimes it boots up and sometimes it doesn't, but I've not been tinkering with it much lately. I've swapped in different CPUs, PDBs, wire harnesses, and SD cards, and it still just boots up once in a rare while. At some point when I get time I'm going to try PinkMonk's suggestion above and swap a different power supply into it.
    #14 1 year ago
    I drove past your house with all my tools with me yesterday. Wish I would have seen this earlier. I could have messed with it!
    #15 1 year ago
    Quoted from the96stang:
    Aw shoot. Stop in for a beer or a coffee any time you're in the area!
    #16 1 year ago
    Hi Sawyer23. Nope, nothing really fixed it for me, sometimes it boots up and sometimes it doesn't, but I've not been tinkering with it much lately. I've swapped in different CPUs, PDBs, wire harnesses, and SD cards, and it still just boots up once in a rare while. At some point when I get time I'm going to try PinkMonk's suggestion above and swap a different power supply into it.
    Thanks for the response @valis666, sorry to hear that. I haven't tried swapping CPU's yet but I plan on doing that and tinkering with it more this weekend. Appreciate your insight!
    This page was printed from https://pinside.com/pinball/forum/topic/led-zep-won-t-boot-tried-many-things-ideas-appreciated and we tried optimising it for printing. Some page elements may have been deliberately hidden.
