Quoted from stinkie:
All connectors appear to be solidly in place. I noticed a couple of burned pins at rectifier board (see image). Not sure if related. The new fuse I previously replaced (F1) is now blown, so I am now searching for crossed wires on bottom of playfield.
[quoted image][quoted image]
Even though a connector is in place, does t mean it’s making good contact. A lot of the time the male & female portions need to be replaced. If they are tarnished and green, it needs to be done. You could also test for continuity to check the pins on the lamp board.
But, since you’re F1 fuse is blowing, you probably have something else going on. Fuse F1 is for the controlled lamps. Start by confirming that bridge rectifier 1 is good. You can use diode test on your dmm. Or, remove connectors J1, J2, J3 from the board, replace the fuse and turn the game on. Check TP1 for around 6 vdc with your dmm.
If the voltage is not there, BR1 is bad. If the correct voltage is there, the problem is later down the line.
If you have a lamp power/ground shorted, it will cause the fuse to blow. Start by checking with your dmm for continuity
