I'm digging through a fair amount of posts and I'm trying to get a handle on the different issues with LEDs.
I have a Fish Tales that I'd like to start replacing incandescents with LEDs. I'm going to start with the back box. I'm guessing my question applies to most 90's Williams WPC pins.
Ghosting - Sounds like this is an issue for mostly inserts as some light may remain on. Am I correct that for the most part I could go with a cheaper LED for GI as those lights are on most of the time anyway? Sounds like there are ROM patches as well which is a possibility.
Flicker / Strobing - I see there are a couple LED types, such as Cointaker Premiums, that say they reduce flicker. Is flicker an issue across all lit areas in the older pins? I like doing things right the first time... if there is flicker, I'm sure I'll see it. Does it mostly annoy people while playing? So potentially I could get Premium LEDs for playfield GI and cheaper LEDs for backbox lighting?
Just looking for some opinions... I don't want to overspend on LEDs if I don't need to... but I also don't want to underspend and not like the results. I got a couple Ablaze LEDs with a pinball life order just to see how they look in different areas.
