I'm trying to justify spending ~$200 to convert a very rough project F-14 to full insert LEDs using $0.39 LEDs from Pinball Life and an LED OCD board. Reason being is I know the inserts are very sensitive to heat on this game and lift easily. I initially thought about using Ablaze's cooler burning 47 lamps but even then, it's still quite a bit of heat, and the machine will be on 24/7. Only 2 or 3 inserts are actually lifted, everything is in better shape than average. What would be best here? As a route operator this is a big expense that will take months to recoup and I need to know if it's necessary to fix something that essentially isn't broke.
