it's sunday morning, so philosophical discussion time...
while reading a post from someone who wants to led a kiss machine (not an em, but it triggered the thought process) so it looks like "original lighting" my mind wandered towards "what did original lighting really look like?"...
my reaction to led lighting in an em has always been "no way, they don't belong there, it's sacrilege to do that"... however, knowing already that i'm gonna use color changers for the fountain in the magic city, my "closed mind" is beginning to open up a bit...
taking into account my prior obsession, and knowing that environment effects color temperature a lot more than people might think...
take pf inserts as an example... having just cleaned the grunge out of the inserts on the MC, it's hard not to notice how much they have yellowed over time... even if i used 44's in them, there's no way (short of replacing the inserts), that the lighting will look "original", as color temp will be shifted by travelling through the insert that is no longer the same color as when it was "new"... it WILL look like "what we are used to", as we are "used to looking at light coming through yellowed inserts"... but that shouldn't be confused with "original"... "original" lighting was likely perceived as being brighter and "colder", due to the lack of shift caused by the yellowing...
to a lesser extent, this would also be true of gi lighting, as the plastics have yellowed, and the white paint under those plastics has either yellowed/gotten grunged... the same is true of bg lighting...
none of the above changes the "physical difference" between a led and an incadescent bulb (primarily the "instant on/off" of an led vs. the residual glow of an incandescent, and light scatter)...
however, i'm beginning to think that the color temp of a "warm" led (or even "colder" ones, depending on the amount of yellowing) may actually result in something that is closer to "original" than an incandescent would... and that our "belief" of "that's what the original looked like" is colored by "what it currently looks like after decades of yellowing"...
iow, the "get off my lawn" mentality of "no led bulbs in an em" may be misplaced...
discuss...
