(Topic ID: 247642)
LED installation
By mark532011
8 months ago
  • 20 posts
  • 11 Pinsiders participating
  • Latest reply 6 months ago by TheLaw
#1 8 months ago
I've followed a few threads discussing the pros and cons of LED conversions on old EM's, my question is how to do it... on SS machines the lights flicker without modifications to the lamp board.. I know there are not any boards, but is there something that must be done to prep for LED's or is it simply - plug in and enjoy?
I'm looking to add a few LED's to the GI attract lights in the backbox of my Target Pool, not a total conversion.
#2 8 months ago
Plug and play for EMs, you're good to go.
#3 8 months ago
Cool. Thanks
#4 8 months ago
LEDs really brighten up some of the darker old games. I put them in my Williams Rocket.
#5 8 months ago
I’ve followed a lot of discussions about the pros and cons of leds in older games and how they alter the “look” of them. But I think in the back box to get brighter lights behind the “game over” light and things like that seems like a good idea and even a 10% drop in power requirements should be good for the game too
#6 8 months ago
The lower heat is nice eXpecially if the glass isnt perfect.
You csn always put less leds in if it seems to be overly bright and will still evenly light it.
Look of for blinking lights though, 454s in some games.
#7 8 months ago
LEDs will ghost in EMs.
I've got one game I think they look ok. The rest not really.
#8 8 months ago
I used non ghosting LEDs on a capt fantastic I had and they worked great.
#9 8 months ago
If you use LED's make sure to get the non ghosting as they just cost a little bit more but then you can put them anywhere without issues.
3 weeks later
#10 7 months ago
I have a few "warm white" LEDs that I use on EMs only in places where the sockets are difficult to access or in places where it doesn't matter much.
That largely means installing them under ball arches or putting them in coin doors. I have several machines where the lamps under the ball arch were covered with colored plastic sleeves and in those cases, the LEDs don't really draw attention to themselves.
But I won't have to replace them anytime soon, and that's always a good thing.
Charlie
#11 7 months ago
It seems like placing them under the pf below the inserts so the “500 point bonus” lights up a little brighter isn’t such a bad thing
4 weeks later
#12 6 months ago
I plan on replacing any lamps on the head unit with LEDs just to keep as much heat away from the artwork. I can see places on my Big Deal where the lamps are causing paint failure.
#13 6 months ago
That makes sense, I doubt many would complain about that even though it’s not stock
#14 6 months ago
Just put in 4 LEDs in my front panel behind some faces. I can't tell the difference in the colors at all! Very nice to know it really works and the artwork is safer. I will pull the trigger for the rest of the head unit LEDs now that I know it works.
#15 6 months ago
Quoted from mark532011:
Anyone that complains will be shown the door.
#16 6 months ago
Sometimes putting LEDs in pop bumpers will make yellowed pop bumper caps look better. This worked well on a Freedom I used to have. But sometimes it makes them look worse. When I tried it on my Grand Prix, it made the normally-yellow pop bumper caps look like tennis balls, so I stuck with incandescents there, even though I have LEDs in the rest of the playfield and they look great.
#17 6 months ago
The LEDs are pretty bright if you look directly at them, but being behind something it seems to calm them down. I have a couple of extra LEDs to run around my horseshoe area but you can look directly at one of them during play. So, I may need to mix and match or take a Sharpie to one side and blackout the part that shows.
#18 6 months ago
My last few EM projects I use nothing but LED, I'm so tired of the new failure prone incandescent.
I find the warm white SMD clear dome from comet mimics the PF GI lamps pretty good and use colored or plain white led in the inserts as you see fit. Frosted ones behind the backglass and sunlight frosted for score reels make them pop a bit.
#19 6 months ago
Quoted from MD_Pinball_Dude:
Another thing to try is using a flex bulb, and then aim it in such a way that it doesn't shine directly into your eyes. Off the top of my head, one place I've done this is in the center target bank in High Speed.
https://www.cometpinball.com/products/1smd-flex
#20 6 months ago
For EM/SS I'll just use a regular incandescent in spots where you can directly see them
$ 52.95
$ 3.00
$ 40.00
Arcade Arts
$ 79.00
Pixels Arcade Games
$ 14.95
COINTAKER.COM
$ 65.00
Texas Pinball
$ 229.99
$ 999.00
$ 11.00
$ 24.95
Hookedonpinball.com
$ 110.00
$ 16.00
$ 189.99
PinballBulbs
$ 218.00
$ 40.99
Lee's Parts
$ 74.00
Id Rather Play Pinball
