The big fluorescent tube burnt out on my LOTR. I was looking and LEDs are now about $15 vs the stock $9. Plus they come in warm white now which will look better behind that backglass. However there seems to be two or more kinds of LED tubes now.
A: Instant on, requires a big electric starter which needs to be wired in and costs another $15.
B: LED where you have to pull out the starter ballast and possibly rewire/replace the tombstone mounts (about $1 each)
C: LED where you supposedly can just slap the new bulb in with no modifications. These cost over $30 and I am not sure if these work here.
D: Is there another option I haven't found besides a big led light panel?
For those of you who have done option B, what all was required? Did you have to replace the tombstones? Could you just put a jumper into the ballast holes to complete the circuit? Which bulb did you buy and where from?
Dan
