I put blue LED 906 flashers in the 3 pop bumpers on a Scared Stiff, and when testing 1 flasher at a time all 3 fire at the same time, also if I remove the LED from the top bumper the other 2 stop working.
While trying to figure out what's going on, I replaced all 3 with regular 906 bulbs and everything went back to normal - no issues. Anyone have any ideas?
EDIT (More Info) - Here is a compact way to show test results...
Bulb Config: Top=bulb, Mid=bulb, Btm=bulb (ALL bulbs)
- Top: Y-n-n // Short hand indicating which bulbs flash for Top Jet test - Top/Mid/Btm
- Mid: n-Y-n
- Btm: n-n-Y
Bulb Config: Top=LED, Mid=LED, Btm=LED (ALL LEDs)
- Top: Y-Y-Y
- Mid: Y-Y-Y
- Btm: n-n-n
Bulb Config: Top=bulb, Mid=LED, Btm=LED
- Top: n-Y-Y
- Mid: n-Y-n
- Btm: n-n-Y
NOTE: I've tried reversing the LEDs but that doesn't seem to make a difference.
