I know a lot of people have been looking for someone to do a run of Run-DMD Clocks/Displays so I've built a batch. Not sure if/when I will do another run so get it now while you can. I'm initially offering them at the same price as the 2019 and 2018 batches were going for. I'm also throwing in FREE SHIPPING between now and 10/03/2021. (NOTE: USPS is "temporarily" raising their shipping rates on 10/04/2021).
If you haven't seen one you need to! These displays are great for your gameroom, your desk, your kitchen, or anywhere. Sit it on a shelf or wall mount.
From top to bottom in the photo. The others in the photo are for reference.
- Pinball (p2.5) DMD (Single color) - 15.0"W x 5.25"H x 1.75"D
- Small (P4) RGB Run-DMD Clock/Display - 21.0"W x 6.0"H x 1.75"D
- Medium (P5) RGB Run-DMD Clock/Display - 26.0"W x 7.0"H x 2.00"D
- Large (P6) RGB Run-DMD Clock/Display - 31.0"W x 11.0"H x 1.75"D
- Jumbo (P7.62) RGB Run-DMD Clock/Display - 39*.0"W x 15.25"H x 2.00"D
- Giant (P10) Yellow Run-DMD Clock/Display - 51.5"W x 20"H x 1.75"D (DMD size is 51.5"W x 14"H x 1.75"D)
Extensive details about extremely similar displays can be found in some previous threads:
- https://pinside.com/pinball/forum/topic/interest-check-run-dmd-clock-winter-2018-batch
- https://pinside.com/pinball/forum/topic/interest-check-run-dmd-clocks-2019-batch
FREE SHIPPING until 10/03/2021 with coupon code EARLY-OCTOBER
** I can immediately ship about 8 Pinball DMD kits with Run-DMD Pinball controllers.
** I can immediately ship about 15 Medium or Large Run-DMD displays
** I can immediately ship about 20 Medium or Large Programmable displays
Pinball DMD Frame Kits - https://pinside.com/pinball/market/shops/1167-gameroom-mods/02128-pinball-dmd-acrylic-frame-kit
Medium RGB Frame Kits - https://pinside.com/pinball/market/shops/1167-gameroom-mods/02382-medium-rgb-led-clocks-displays-and-frame-kits
Complete Medium/Large RGB Displays - https://pinside.com/pinball/market/shops/1167-gameroom-mods/05352-medium-large-rgb-led-clocks-display
Misc DMD Display accessories - https://pinside.com/pinball/market/shops/1167-gameroom-mods/04742-dmd-accessories
DETAILS ABOUT MEDIUM AND LARGE DISPLAYS
these displays are similar to the Medium Gameroommods RGB displays and the J_M_ RGB style clocks. Some key specs of the Clocks/Displays are as follows:
- Each display has 2x 64x32 LED panels mounted side by side for 128x32 dot resolution.
- Each display has the same number of pixels as a Pinball DMD - 4096 pixels total.
- The panels use the larger LEDs to make the pixels look as close together as possible.
- Medium RGB Run-DMD Clock/Display (P5) = 26.0"W x 7.0"H x 2.00"D
- Large RGB Run-DMD Clock/Display (P6) = 31.0"W x 11.0"H x 1.75"D
The "Run-DMD White" versions integrates the following into the fully assembled display:
- Run-DMD White Clock/Displays can only show a single color at a time
- User can switch between red, green, blue, yellow, magenta, teal or white
- Can run your own animations and graphics plus those created by others
- FULLY ASSEMBLED. Unbox. Plug in. Adjust time. Enjoy.
- 1x Run-DMD White with un-programmed SD card pre-installed
- 1x Run-DMD Edge/White cardboard insulator
- 2x Medium (P5) or Large (P6) RGB LED panels
- 1x Custom laser-cut Front acrylic grey tint panel
- 1x Custom laser-cut Rear acrylic grey tint or black opaque panel
- 1x Power harness
- 1x Power brick - 10a/5v
- 1x Power cord - 4' (not provided for orders shipped outside North America)
- 2x data cable for connecting the LED panels to one another and to the controller.
- 1x All the hardware for mounting everything together.
The "Programmable" versions integrates the following into the fully assembled display:
- If we are out of the Run-DMD version, buy this one and put your own Run-DMD white in
- Can be used as a "message sign" as you may have seen in many storefronts
- When programming nearly unlimited colors can be shown at once. This a "full-color" display
- Programmable versions are "Run-DMD Ready" and are upgradable to a Run-DMD White
- Controller brand and model will be listed on the label on the back of the display
- FULLY ASSEMBLED. Unbox. Plug in. Program. Enjoy.
- 1x Generic LED panel controller with a test program preinstalled on it.
- 1x Power harness
The Combo 2-pack versions
- 1x Run-DMD white display
- 1x Programmable display with upgraded wireless programmable controller
Mounting/Displaying
- Mount on the wall - There are 2 keyholes 16" on center
- Place on a shelf or desk - The display is stable when sitting on a flat level surface.
