Do I have to change a board out to convert to LEDs. I'm a noob and this is my first attempt and I replaced literally 10 to see how they look and some don't light up. If you have a minute please inform me
Yes, you'll need these. Otherwise, the LEDs will flicker. You could also use an Alltek lamp driver board, more expensive though.
http://www.siegecraft.us/presta/index.php?id_product=44&controller=product&id_lang=1
If they dont light try installing bulb 180, some bulbs only work intalled one way some it doesnt matter
You don't HAVE to get a new board, but it makes it a mindless changeover, and if you have any bad SCRs on the old one, you won't have to fix them.
Not every LED bulb will flicker. Sometimes someone will have repaired the lamp board with higher spec SCRs and all the repaired lamp circuits will flicker. You can add a resistor to just the bulbs that flicker.
https://pinside.com/pinball/forum/topic/classic-ballystern-led-adapter-kit-review
Those old sockets will often be corroded. You can clean them with a Dremel and one of these bits from HF:
The spring at the bottom of the socket is old, don't break it off or it can short out the SCR that drives the bulb.
Quoted from vid1900:Those old sockets will often be corroded. You can clean them with a Dremel and one of these bits from HF:
Or a Nifty socket cleaning brush.. http://www.niftyled.com/pinball-bulb-socket-cleaning-brush/
Quoted from iwantansi:Or a Nifty socket cleaning brush.. http://www.niftyled.com/pinball-bulb-socket-cleaning-brush/
I'd worry that little pieces of the metal bristles would break off and short the socket/SCR.
This page was printed from https://pinside.com/pinball/forum/topic/led-conversion-silverball-mania and we tried optimising it for printing. Some page elements may have been deliberately hidden.
