I started learning by taking apart VCRs and the like (reassembly optional) and fixing lamps when I was younger. The best way I've found to pick up hobbyist electronics tinkering and troubleshooting skills is to find a project that's interesting enough to you that you'll follow it through to completion and is at the edge of what you feel comfortable with. Start with something simple and either practical or decorative like a motion-activated light switch or an LED cube.
Some more information on what you're trying to get started on would be good, for instance do you have a project machine that needs repairs? Just trying to save on repair costs? Are you considering repairing pins as a hobby or occupation? Just curious? Also be aware that "Electrical Engineering" is a pretty lofty goal for a thing to pick up on the side and there's a reason that both a four-year degree and a further four years of practical work experience is required to even attempt the exam to become a licensed Professional Engineer. Pinball diagnostics and repair is more along the lines of technician work.
If there's one in your area, places like TechShop and other maker spaces usually have classes. Fees, format, equipment available, and skill levels are kind of all over the map, but an intro class would probably get you some good hands-on time if you're starting from an "I know these things exist" standpoint. It'll also probably save you some money up front if you don't already have tools or know what tools you might need. They should also give you some basic safety instruction, which you absolutely should have. If they don't start with that or offer a free safety intro session, call them out on it and ask for a refund.
Soldering itself isn't too hard. Watch a video or two on the web, I'm sure they're available. Practice on bits of twisted stranded wire and then grab a through-hole breadboard (they're also called protoboards) that you can practice soldering and desoldering through-hole connections on. Sparkfun is great for stuff like that. They can be finicky and are worth practicing. The first lab in an an instrumentation course I used to teach was creating a cube out of eight wires twisted and soldered together, saved a lot of time and burnt components (and body parts) in the long run.
Whatever you do, ask questions! It's one of the best ways to learn. Also messing things up and then figuring out how and why it got messed up and what you could do better next time. Also be safe.
