Very basic question for complicated task... Trying to add my own audio to a Stellar Wars pin. I have an audio trigger board loaded with sounds.If I test it with a micro switch you click it , the ground & live wires I have attached touch so I get a connection and the board knows to play a sound. I assumed leaf switches have the same basic setup. 2 non touching pieces of metal, push button so metals touch and the machine knows there was a connection. Problem is when I attach the wires to a leaf switch it keeps "talking" meaning there is some sort of connection between the 2 pieces of metal. I even stripped the 2 wires connected to the switch to make sure there was no cross contamination but it still kept looping the sounds because there was a constant current flowing. Am I not understanding the basic premise of a leaf switch?
FYI, Both metal pieces on the switch(es) are not accidentally touching.I made sure of that
