(Topic ID: 255575)
Swinks Pinball - mods, reproduction parts
By swinks
  • 330 posts
  • 48 Pinsiders participating
  • Latest reply 11 days ago by J85M
  • Topic is favorited by 53 Pinsiders
There are 330 posts in this topic. You are on page 7 of 7.
#301 7 months ago
quick print just to test fit and sizing - a few small adjustments needed but getting close.
flasher coming through the vents for the moment
9972E309-D21D-4C3A-A8BD-B0EC9F961A1B_1_105_c (resized).jpeg9972E309-D21D-4C3A-A8BD-B0EC9F961A1B_1_105_c (resized).jpegF37390E3-06A5-4898-94CE-E9DDF4D14364_1_105_c (resized).jpegF37390E3-06A5-4898-94CE-E9DDF4D14364_1_105_c (resized).jpeg
#302 7 months ago
Great start and looking forward to your end result as i know there is more to add.
#303 7 months ago
UFO and Bots are done and happy with the variety of places they can be mounted and angles it can be set at. The UFO bot comes with a 10 deg up and 10 deg down mount and a post led inside so glows out the front, top and tractor beam below. The UFO can also be mounted at any banking angle level, 90 degrees or even up side down. Tri-Bot comes in 3 legs swept back or standing each with 2 different height post mounts with head and legs that you can adjust to face different directions. Rocket Bot can be mounted right down on the post up to about 10mm above it's base making him look like he is landing. Still waiting on decals for Tri-Bot and Rocket Bot so not quite finished.
09E37AA6-BF45-4B58-804F-C57FA6328A63_1_105_c (resized).jpeg09E37AA6-BF45-4B58-804F-C57FA6328A63_1_105_c (resized).jpeg35B0D2AC-D67F-42F8-8DE0-E8FA39C45472_1_105_c (resized).jpeg35B0D2AC-D67F-42F8-8DE0-E8FA39C45472_1_105_c (resized).jpeg5EEC6D75-7625-4768-9F73-679FE9F8E986_1_105_c (resized).jpeg5EEC6D75-7625-4768-9F73-679FE9F8E986_1_105_c (resized).jpeg750A9765-8CE6-4F73-AFDD-1C7AE3D2D287_1_105_c (resized).jpeg750A9765-8CE6-4F73-AFDD-1C7AE3D2D287_1_105_c (resized).jpeg9B452C2A-33E5-4C0E-9BC8-DA9797993AEF_1_105_c (resized).jpeg9B452C2A-33E5-4C0E-9BC8-DA9797993AEF_1_105_c (resized).jpegE7EC4A79-017A-4736-87FF-7654BB5DAE76_1_105_c (resized).jpegE7EC4A79-017A-4736-87FF-7654BB5DAE76_1_105_c (resized).jpegFD425CA1-68DC-4F8F-94C4-AA1814FADB50_1_105_c (resized).jpegFD425CA1-68DC-4F8F-94C4-AA1814FADB50_1_105_c (resized).jpeg
#304 7 months ago
I setup a dedicated thread for my mods if anyone is interested in them
https://pinside.com/pinball/forum/topic/foo-mods-bots-ufo-area-51-building-pro#post-7664821
post or send me a pm to be removed or added to the wait list
3 weeks later
#305 6 months ago
Here are revised and updated manuals for the recent GB Mods that started going out yesterday.
Stern - Flat Iron Mod - Manual Rev2.pdfStern - Flat Iron Mod - Manual Rev2.pdfStern - Library Mod - Manual Rev3.pdfStern - Library Mod - Manual Rev3.pdfStern - Sky Mod - Manual Rev3.pdfStern - Sky Mod - Manual Rev3.pdf
3 weeks later
#306 5 months ago
FINALLY finished the Foo Fighter Pro Area 51 Building. It has UV reactive green trimming details, red lighting beacon and internal lighting and then RGB light front building. The building also gives a clearer view of the flasher with the flasher relocated to the mods mount. The Area 51 Building also comes with a mount for the Keep out plastic with a ball diverter if ever the ball gets air behind there so no trapped balls. I will be upgrading the beacon to be flashing off a ramp trigger and plan to add an additional feature in front of the building.
IMG_1316 (resized).jpegIMG_1316 (resized).jpegIMG_1317 (resized).jpegIMG_1317 (resized).jpegIMG_1318 (resized).jpegIMG_1318 (resized).jpegIMG_1350 (resized).jpegIMG_1350 (resized).jpegIMG_1352 (resized).jpegIMG_1352 (resized).jpeg
3 weeks later
#307 5 months ago
On a more fun note, after years of wanting to do the Fire Station the 1st pass prototype (just one colour at the moment) is made with a mini ecto light bar above the spinner and might do a mini GB sign a try as well.
Still need to make a few changes and then work out a good way to repeatedly make with the various parts coloured.
Is approx 60mm wide x 100mm high x 145mm back.
Also don't worry all the windows will be opened up and replaced with backlit resin.
Unlike the Stern / Mezelmods and Wolfcub's this allows a view to the city at the back and is more in fitting with my Library and Flat Iron Mod scale.
Before
879832EB-B384-4F7D-B42F-9FAA595FB349_1_105_c (resized).jpeg879832EB-B384-4F7D-B42F-9FAA595FB349_1_105_c (resized).jpeg
After
97A07BA5-BB60-42D8-BBFB-C11E5CE25A0E_1_105_c (resized).jpeg97A07BA5-BB60-42D8-BBFB-C11E5CE25A0E_1_105_c (resized).jpeg
This shows the depth of the mod
EE7C37E1-670D-4E68-8765-FC9AE43445C9_1_105_c (resized).jpegEE7C37E1-670D-4E68-8765-FC9AE43445C9_1_105_c (resized).jpeg
This shows the Fire House with my library and flat iron mods
F57E0FE9-ABEB-46C4-B745-634C296EEF3A_1_105_c (resized).jpegF57E0FE9-ABEB-46C4-B745-634C296EEF3A_1_105_c (resized).jpeg
#308 4 months ago
I gotta say you make some of the best mods out there. I just installed the Flat Iron building last night and wow!!! Amazing work man. Didn’t even reference an installation video as it so well crafted and was super easy to install. Absolutely put me down for a Firehouse !! Your stuff is second to none. Cheers!!
#309 4 months ago
Quoted from Flash71:
Thanks mate, your review is very much appreciated and so happy that you like it and appreciate the design and quality.
Sorry I don't do install videos but feel the install guides are detailed and gets most people through.
Question of curiousity - was the fluro green plastic down the back of the flat iron an existing mod as stroke of luck that they work together.
Enjoy
3 weeks later
#310 4 months ago
Ghostbusters Fire House Mod is off to the manufacturers
#311 4 months ago
#312 4 months ago
#313 3 months ago
Another 10 x Snackbar Mods ready for Christmas, send a pm if you want one
01C285E3-6B5C-4492-B319-37FAB78F72D3_1_105_c (resized).jpeg01C285E3-6B5C-4492-B319-37FAB78F72D3_1_105_c (resized).jpeg051668D5-BD76-451E-9CF4-2FA88D10F9E4_1_105_c (resized).jpeg051668D5-BD76-451E-9CF4-2FA88D10F9E4_1_105_c (resized).jpeg3C3A395F-D900-4B93-84A3-AFA2ED1DE3F0_1_105_c (resized).jpeg3C3A395F-D900-4B93-84A3-AFA2ED1DE3F0_1_105_c (resized).jpeg
3 weeks later
#314 77 days ago
have been wanting to do this mod for ages where a custom sign on the back ramp sync's with the lockdown button to show you the button status - yellow / green / red. I made 2 different lenses - Area 51 signage and then Bombs Ready. I know it is meant to be Tractor Beams but like the idea of bombs especially with one on the van.
Everything is home printed and no paint and the bombs ready is a 2 colour print where as the Area 51 is a decal.
DFAD3EF7-2445-47BF-926A-6FEDC8A0B810_1_105_c (resized).jpegDFAD3EF7-2445-47BF-926A-6FEDC8A0B810_1_105_c (resized).jpegD3BDC657-44EE-4AC5-A886-C33966117B41_1_105_c (resized).jpegD3BDC657-44EE-4AC5-A886-C33966117B41_1_105_c (resized).jpegA7B8E604-FE42-4F71-BACF-96D79DC3E74D_1_105_c (resized).jpegA7B8E604-FE42-4F71-BACF-96D79DC3E74D_1_105_c (resized).jpeg0A169B61-5882-47E0-B3BA-E5BC0AD954EF_1_105_c (resized).jpeg0A169B61-5882-47E0-B3BA-E5BC0AD954EF_1_105_c (resized).jpeg8C713AE3-8A73-40C1-90C4-E43B6245DEF2_1_105_c (resized).jpeg8C713AE3-8A73-40C1-90C4-E43B6245DEF2_1_105_c (resized).jpegCCCC0D92-D0C0-4AC1-A970-FFDBE3D9B8C8_1_105_c (resized).jpegCCCC0D92-D0C0-4AC1-A970-FFDBE3D9B8C8_1_105_c (resized).jpeg
0A169B61-5882-47E0-B3BA-E5BC0AD954EF_1_105_c (resized).jpeg0A169B61-5882-47E0-B3BA-E5BC0AD954EF_1_105_c (resized).jpeg8C713AE3-8A73-40C1-90C4-E43B6245DEF2_1_105_c (resized).jpeg8C713AE3-8A73-40C1-90C4-E43B6245DEF2_1_105_c (resized).jpegA7B8E604-FE42-4F71-BACF-96D79DC3E74D_1_105_c (resized).jpegA7B8E604-FE42-4F71-BACF-96D79DC3E74D_1_105_c (resized).jpegCCCC0D92-D0C0-4AC1-A970-FFDBE3D9B8C8_1_105_c (resized).jpegCCCC0D92-D0C0-4AC1-A970-FFDBE3D9B8C8_1_105_c (resized).jpegD3BDC657-44EE-4AC5-A886-C33966117B41_1_105_c (resized).jpegD3BDC657-44EE-4AC5-A886-C33966117B41_1_105_c (resized).jpegDFAD3EF7-2445-47BF-926A-6FEDC8A0B810_1_105_c (resized).jpegDFAD3EF7-2445-47BF-926A-6FEDC8A0B810_1_105_c (resized).jpeg
#315 77 days ago
Also the list closes on the Fire House Mod Tuesday 12th Dec for first and possible only run - $200 non-refundable deposit to lock in a place.
more info here - check out my 3-5 posts from this point
https://pinside.com/pinball/forum/topic/ghostbusters-gozerian-sky-mod/page/7#post-7881500
suits Ghostbusters - Pro / Premium and LE
38DF21EF-CF79-4787-97A2-E1EB3FB858D4_1_105_c (resized).jpeg38DF21EF-CF79-4787-97A2-E1EB3FB858D4_1_105_c (resized).jpeg4AFD8125-5A00-40E0-A83D-6B3CC552DA21_1_105_c (resized).jpeg4AFD8125-5A00-40E0-A83D-6B3CC552DA21_1_105_c (resized).jpegPinside_pm_6697341_4 (resized).jpgPinside_pm_6697341_4 (resized).jpg
#316 68 days ago
I was not notified that Shapeways had a flash sale (which ends today) so if you need any pinball - use the following codes and head to my page of what you can possibly buy.
https://swinks.com.au/reproduction-parts-1
Screen Shot 2023-12-16 at 10.17.20 am (resized).pngScreen Shot 2023-12-16 at 10.17.20 am (resized).png
#317 65 days ago
A customer installed the Fire House Mod into their Premium GB. They purchased both the GB logo spinner topper and the Ecto Spinner Topper. The Art Blades and Fire House work so well together with the stream coming out of the roof top.
427eb2748c5c52f9499f14f2f8c355f05d9e3f4b (resized).jpg427eb2748c5c52f9499f14f2f8c355f05d9e3f4b (resized).jpg64d64130f9f0be5d651cdfa37859ab2ebd043ff2 (resized).jpg64d64130f9f0be5d651cdfa37859ab2ebd043ff2 (resized).jpg7ee8d2f03956a8c27ee39656635cc01b1a07b2c2 (resized).jpg7ee8d2f03956a8c27ee39656635cc01b1a07b2c2 (resized).jpg
#318 65 days ago
went and had a look at the Twippy awards categories and selection options and they listed nearly every mod under the sun but not a single one of my 10 mods that went into production this year....
#319 65 days ago
That’s crazy, but do you or the community have to advise?
I had heaps of positive reaction when installing your UFO mod into another FF the other night.
Let alone the Area 51 building
#320 65 days ago
Quoted from oldskool1969:
Thanks mate, much appreciated
I don't care if I did not win anything, but when nearly every other mod created this year is listed but none of mine for the year are even acknowledged - it is a bit of kick in the guts.
#321 65 days ago
Quoted from swinks:
Paul's Atomic Godzilla not listed either mate. He's emailed them about it but I bet they are inundated with complaints atm.
#322 65 days ago
Quoted from stumblor:
just to be clear it isn't a dig at you, it's there inconsistencies and errors which occur every year in various categories
#323 64 days ago
Please add me to your firehouse mod list. Thanks
#324 64 days ago
Quoted from swinks:
They wrote back but I declined to enter on principle, as it should be about being recognised (it is in their title) and not about self promoting to be added.
#325 64 days ago
Quoted from brucea1956:
you are added to the Fire House List.
#326 63 days ago
Quoted from swinks:
Looks Great!
#327 62 days ago
Mini NYC in Ghostbusters
(care of BoilerUp - great photo)
3 weeks later
#328 39 days ago
Just about finished another project out of necessity but will be offering to pinheads soon.
I can't justify the Marco Jack Stands as they are not cheap and a set of 2 ends up being over $400 AUD (for 2) so purchased some jacks and designed some jack stands and 3d printed them (blue parts) and modified the jacks for a total cost of $85 AUD for 2 jacks plus the printed parts and a few bolts, nuts and washers. They work around pin footies of different designs to lift the front or back of the cabinet off the ground to adjust the levelers - quickly and easily and a much cheaper price.
2CFB06C0-EB44-4B4D-ABFD-C5ED09BB2C8A_1_105_c (resized).jpeg2CFB06C0-EB44-4B4D-ABFD-C5ED09BB2C8A_1_105_c (resized).jpeg8E8FDC54-D593-4CAE-AB3D-EEE95686DC16_1_105_c (resized).jpeg8E8FDC54-D593-4CAE-AB3D-EEE95686DC16_1_105_c (resized).jpeg
3 weeks later
#329 12 days ago
Recently I did my version of the pinjacks but then thought why not just one jack to lift up at the centre of the game to adjust around any type of furniture sliders / pin footies. Also no modifying of the jacks but requires a few bolts, 20 x 20mm maker aluminum profile and printed parts
this is a breeze now and so quick and portable
893E2965-A0A5-4792-8DA0-5902EBA12545_1_105_c (resized).jpeg893E2965-A0A5-4792-8DA0-5902EBA12545_1_105_c (resized).jpegD57E2AF1-AB97-4213-AC00-6889D09C8C88_1_105_c (resized).jpegD57E2AF1-AB97-4213-AC00-6889D09C8C88_1_105_c (resized).jpegF6DFA096-48F0-4864-8D62-7E45069E55DB_1_105_c (resized).jpegF6DFA096-48F0-4864-8D62-7E45069E55DB_1_105_c (resized).jpeg
#330 11 days ago
Quoted from swinks:
Bloody brilliant Jady, are you going to be selling these as complete units or what mate? I’d love to get/make a couple of these to save the back.
This page was printed from https://pinside.com/pinball/forum/topic/latest-pinball-parts-mods-and-shirts-by-swinks/page/7 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
