I just purchased a Last Action Hero and I noticed the playfield magnets were not working during multi-ball and confirmed this in the diagnostics. I noticed under the playfield each magnet has a fuse in a block located near them. All 3 fuses were burned on mine. I pulled them out and they were 2a 250v slow blow fuses. It seems like the game uses mostly 5a so I'm not sure if the 2a are correct. Does anyone know if the 2a are the correct fuses for that application? Anyway I replaced all 3 fuses with the same 2a slow blows and the magnets worked again! For a few games at least... Until it burned all 3 fuses again. Looking around a bit I see that this can be a common issue. Namely it looks like people had issues with the magnets burning out the F9 fuse which also controls the ripper. Mine is not doing that its just blowing the 3 under the playfield fuses. I see a few people used a Clays guide to modify the magnet board by replacing the mofsets and adding a cap on the IC chip but I can't find the guide anywhere. I would appreciate any assistance in getting my magnets working again!
