I just recently picked up a Data East Last Action hero from a friend. The previous owner had shorted out a bunch of chips on the MPU by doing some soldering work while the machine was plugged in. This fried the switch matrix and so all switches were firing at once. I had board work done on the MPU to fix these issues and the game mostly plays fine. However, sometimes the CRANE targets are having issues resetting, and one out of three balls or so the skill shot won't work right. It seems to happen if there are already some targets knocked down. The 3rd drop target will be lit, rather than having the lights chase up and down, and some of the targets will remain down. It's weird but the animation on the DMD seems to be different as well. Instead of having a moving helicopter where Jack Slater is moving a gun back and forth, the gun is just stationary.
Sometimes the CRANE targets hesitate a couple times before finally being able to fully reset. I've had a few times where I hit the shot behind the targets which resets them, and they never actually reset. On one occasion where it was messed up on the skill shot and some targets were down already, the skill shot hit the target behind the drop targets and reset them, then I drained. Then on the ball save, the skill shot was now working correctly for the ball save.
The game seems to think there's a ball missing sometimes. One time when the skill shot was messed up, I launched the ball, then it said ball missing, and the game ended abruptly. So I definitely have some weird stuff going on. And I'm hoping we didn't miss something on the MPU. Although it seems that the CRANE targets mechanism itself may have something going on which is causing the targets not to reset properly. I guess I'll also add that the game does think the targets are upright when they're failing to reset. One time when the targets failed to reset, I hit the 2 remaining standing targets, and this didn't trigger the crane functionality to start. I had to hit the back target to reset them, then knock them all down in order to start the crane. So I'm leaning towards the CRANE target mechanism having an issue. Which begs the question: is this a part that's actually available to purchase? Thanks in advance for any help.
