Quoted from caker137:If you shoot the ramp or you fall into the chicken scoop from the pops you get the Frank animation and the Frank award goes up.
Craig
Normal then? Interesting.
Craig
The top horizontal line on my DMD is always blank - DMD functions fine otherwise
Anyone else experienced this issue that can point me in the right direction for possible fix?
Quoted from Oscope:The top horizontal line on my DMD is always blank - DMD functions fine otherwise
The dmd itself may have an issue. But before you start replacing it, have you tried reseating the ribbon cable that goes to it? Btw, a color dmd looks awfully good on it.
My brother's machine started reseting during game play. He said it seems to do it everytime the crane is activated and I'm not sure if it does it at any other times like multiball or other times when more power is being drawn.first thoughts are power supply since it shuts down as more power is needed with the crane. I'm heading over there tomorrow and I'll check the bridge rectifier and see if that's the problem,I'm not much of a tech but that I can do and in the past it's been my problem with these symptoms most of the time. I just figured I'd check in to see if anyone else experienced the same thing and might have some insight for me like a bad diode or shorted wire.
I can almost guarantee it’s an issue on the power supply. I’d bring a spare working one if you or they have another Data East.
Quoted from chuckwurt:I can almost guarantee it’s an issue on the power supply. I’d bring a spare working one if you or they have another Data East.
I wouldn't bet against you unfortunately this was my only Data East. I should be able to get it sorted myself, either fixed or diagnosed and sent out.my soldering is getting better and it's not mine anymore if I mess it up working on it for free so maybe I'll try my first board work other than a remote battery install.
Quoted from Puffdanny:My brother's machine started reseting during game play. He said it seems to do it everytime the crane is activated and I'm not sure if it does it at any other times like multiball or other times when more power is being drawn.first thoughts are power supply since it shuts down as more power is needed with the crane. I'm heading over there tomorrow and I'll check the bridge rectifier and see if that's the problem,I'm not much of a tech but that I can do and in the past it's been my problem with these symptoms most of the time. I just figured I'd check in to see if anyone else experienced the same thing and might have some insight for me like a bad diode or shorted wire.
Sounds like electrolytic capacitor issues to me. All the smaller ones need to be replaced as they are the most likely to leak.
Quoted from Supagoat:does anyone knows what could be the problem with my flipper? it get stuck and doesn’t move unless I press start or I push the left flipper few times. I was thinking it could be the coil but not sure if it could be something else. thanks!
Mechanical If it stays up with the game off. Rebuild the flipper.
Quoted from Supagoat:with the game off stays down. everytime I press start goes back to normal
Post a picture of the underside of the flipper assembly.
When you turn the game on, does the flipper engage?
thank you. I just checked it and everything looks good to me. how could I know if it’s the coil or something else? thanks
Do you guys know what your pitch is set at for this game? Mines at 5.something degrees with the legs jacked almost all the way up and it still feels like it's a bit slow.
If you have 3” leg levelers and they are jacked up all the way in the back, it’s should be closer to 7 degrees.
Front legs all the way down.
Anyone looking for an alternate translite for these? I have mocked something up and may have a few for north america centric shipping.
The nicer movie poster art style ones i have seen are mainly from the UK.
Pm me if you are interested, here is a link to a nascar translite i did as well.
https://pinside.com/pinball/forum/topic/custom-alternate-translite
Quoted from trueno92:Anyone looking for an alternate translite for these? I have mocked something up and may have a few for north america centric shipping.
PMing you
Quoted from BroMan90:So much better than the original.
My buddy stopped by and is really likes the deep ruleset of it, it is impressive for the time it was made. And everyone says this is based on sys11 architecture??
Anyway, it really makes the original translite look like it was home made, not this one!
Doesn't improve my scores tho... this game is brutal.
Can anyone point me in the direction to get a spinner?
9afedb70912e12a86de95c2c5d021cdd3a24ae9f (resized).jpgQuoted from chuckwurt:So PBR says their generic white spinner works in LAH. I got that and decals from Mr. Tantrum.
I’ll report back on how everything works![quoted image][quoted image]
Link to this decal?
Quoted from trueno92:And everyone says this is based on sys11 architecture??
Yes, Gary Stern had rights to the Williams hardware but not the software. This is why some early Data East power supplies, flipper boards and displays interchange. There is a small number of System 11 games you can actually swap MPUs as well.
Happy to see the "Facelift" was successful!!
If anyone else wants to let their's go, "under the knife"...
.. I know a guy....
anyone catch any easter eggs in this game? been catching the attract mode and noticed that Lyman Sheets is credited along with john Borg, as well when it says dot matrix, it actually says DOT MADNESS - and i have to admit, this has some of the best dot animations in any game of this era, considering the technology and resolution they were working with.
with a PIN2DMD colorization, its even better!
Not sure if any of you guys caught this but wow, crazy insight here that really turned me on to the movie.
First time seeing it at 43 yrs old...
Quoted from PinballManiac40:Sounds like electrolytic capacitor issues to me. All the smaller ones need to be replaced as they are the most likely to leak.
I'm about to order a cap kit and figured if all the caps are getting changed I might as well do the bridge rectifiers too.does anyone know the proper ones without to much trouble? Sometimes I wish I wouldn't of dropped out of college electronics after 6 weeks.
Quoted from trueno92:Not sure if any of you guys caught this but wow, crazy insight here that really turned me on to the movie.
I enjoyed the review but the guy is reading too much into the movie and ignoring the horrible studio meddling and endless rewrites and re-shoots. Hell the action script writer they were mocking in the movie actually ended up being hired to do some of the re-writes.
Its a movie that had a great idea and a few good scenes but was never fully fleshed out and simply destroyed in rewrites.
Hi everyone,
Have a minor issue at moment with LAH where all the lights start flicking on and off every couple of seconds while playing.
Only flickers non stop but stops temporary when do game rules eg dynamite values, shields, super crane etc and once the game plan done it goes back to flicking on and off.
Any idea
Cheers
Brett
My translite order from Trueno92 arrived quickly and looks great.
Thanks Andrew.
A gameplay vid showing the most recent pin2dmd colorization.
A lot of nice work here, esp at the 2nd multiball 4:20
Quoted from trueno92:Anyone know how to get specials lit? It happens but i dont know how to trigger it.
Hi, with Gamerom V1.13 it works like this:
Special lit when Bonus is > 25M- (freeplay users have never seen this feature until now)
If you set special to award extra balls, this is what you will get when you collect special.
Quoted from trueno92:A gameplay vid showing the most recent pin2dmd colorization.
Well I am convinced. That is sooo much better now and looks fantastic!!!
Ok, I have this weird behavior of my sound. Doesn't seem to be related to anything that is ongoing within game play.
My sound volume suddenly dropps, and cuts out all low frequency including the sub woofer in the cab. Stays like that for a while and sometimes the sound kicks back in for a bit.
Any idea where to start?
Quoted from StrangeSubset1:Ok, I have this weird behavior of my sound. Doesn't seem to be related to anything that is ongoing within game play.
While the machine is off, turn the volume control all the way up and all the way down a few times. This will clean the pot and may help with volume cut out.
Quoted from Scoot:While the machine is off, turn the volume control all the way up and all the way down a few times. This will clean the pot and may help with volume cut out.
I am sorry for my ignorance, but volume is controlled digitally, no way to adjust unless the machine is on. I don't believe there is a manual pot for it. Please correct me if I am wrong and point me to where I can find it
This page was printed from https://pinside.com/pinball/forum/topic/last-action-hero-club-come-on-in/page/58 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
