Last Action Hero club, come on in!
(Topic ID: 67379)
By Matt_Rasmussen
5 years ago
  • 1,968 posts
  • 225 Pinsiders participating
  • Latest reply 4 days ago by JSBebop2071
  • Topic is favorited by 76 Pinsiders
There are 1968 posts in this topic. You are on page 38 of 40.
#1851 33 days ago
trying to find a spot for my Jack Slater, but he wont fit. He would look great in the game but He's to tall.
#1852 33 days ago
Quoted from Mr_Tantrum:
I need some help from the LAH community please. In designing my topper decal, it has been brought to my attention that there are actually 2 screws/rivets that go through the decal which mounts to a disk which is fastened to the rectangular plate. I’m trying to understand the exact setup but photos are scarce. So, I have a few questions in order to account for making the holes in my decals.
- Are screws or rivets used? From the good pics I have seen they look like rivets but not the pop kind. Basically trying to figure out if they are easily removable for decal install or if they are permenant and the decal needs to fit over them.
- if screws, what is the hole diameter that the screw goes through?
- if rivets, what is the head diameter of the rivet?
- are the screws/rivets placed at the exact vertical center of the decal?
- what is the horizontal distance in mm between the exact centers of the two screws/rivets?
- I saw a pic w/o the decal or disk mounted and the surface is flat with the two holes. Personally, I would choose to mound the new decal on the disc then use some adhesive to secure the disk to the plate so that riven/screw heads are covering the decal. Is this practical/preferred? I guess I could offer two version of the decal (one w/ holes so that it fits over the screws/rivets and one w/o for those who want to get rid of the screws/rivets) but was trying to simplify.
Any help is greatly appreciated as I’m very close to finalizing my design and offering them for sale.
20190120_130623 (resized).jpg20190120_130638 (resized).jpg20190120_130644 (resized).jpg
#1853 33 days ago
It doesn't look like it's a sticker but a typical pinball plastic that you would see on the playfield
#1854 33 days ago
Quoted from Jon9508:
Those are good shots. I’m noticing the background of the rhino is really orangish instead of pure yellow, so I will adjust for that. FYI, I am going to have a few options which will include a replacement dust that will mount without rivet heads covering any of the graphic. More to come soon.
All I need at this point is for someone to provide me the hole diameter for the rivets in the rectangular plate, and then I will have all the measurements I need. Since the rivets are not meant to be removed, will need to be someone who is already missing the emblem disk.
#1855 33 days ago
The rhino is orange for sure. The rivets look to be the standard 1/8 dia. But not 100% sure. Without taking it apart
#1856 33 days ago
Yea, really need the hole diameter for sure before I can finalize the design on my alternative snap in 3D printed plate, but I don't expect someone to drill out there rivets to give it to me. I know there are plenty out there who are missing the piece with the holes exposed.
Would you mind giving me one more shot? Heads-on closeup (in focus) with good lighting, so that I can grab the best representation of that orange color.
#1857 32 days ago
#1858 32 days ago
Great, one more question. Are the 4 graphics sitting on the blue background supposed to be a paler yellow than the eagle or have they faded?
#1859 32 days ago
Here is updated graphic with new colors.
#1860 32 days ago
Mine are faded. I couldnt even make them out until I looked at yours
#1861 31 days ago
Looks like your brown is a little off. That was with a camera flash, so perhaps a little blueish tint on my end.
#1862 31 days ago
Quoted from mbwalker:
I don't think the color is going to be THAT noticeable of a difference. But here you go to see for yourself. The outer ring is more of the original, and the inner ring is what has been reproduced. Either color would suffice for a replacement. The emblem is a quick glance marker on the game. I wouldn't be too concerned about it being 'perfect'.
#1863 31 days ago
Thanks, I like your color better, so here is update.
#1864 31 days ago
Quoted from TheCapn:
I don't think the color is going to be THAT noticeable of a difference. But here you go to see for yourself. The outer ring is more of the original, and the inner ring is what has been reproduced. Either color would suffice for a replacement. The emblem is a quick glance marker on the game. I wouldn't be too concerned about it being 'perfect'.[quoted image]
Don't disagree Cap, was just pointing it out. I had been taking a fair amount of pictures and measurements (sent via e-mails to Tant), with and w/o a flash...so wasn't sure if he caught the difference of the brown or not.
#1865 31 days ago
FYI, idea is not to match perfectly, but to create a representation that closely represents the original, including the coloring. I am very close to finishing both the decal and the mounting disk (for those who are missing it). Hopefully by the weekend, I can have some pics from the one who originally requested that I design a replica emblem, and I will detail the options to everyone.
As a precursor to that, I will most likely offer as follows:
1) Decal designed to be applied on top of the current one (ie on top of the plastic disk). This decal will have a gloss vinyl laminate, and holes cut out to fit over existing rivets.
2) Laminated decal as above with no holes cut to be used however you will.
3) An assembly designed to fully replace the existing rivets, disk, and decal. This will be a 3D printed disk with built in fasteners that will go through the existing holes on the rectangle bracket and be secured from behind. The decal will be on the front of the disk (laminated as above), but the design removes the rivet heads that cover part of the graphic. To use this, you will have to remove the current plastic and drill out the 2 rivets.
#1866 31 days ago
Also, I just sent you an email. Anyway you could get me one final measurement of the rivet head diameter on the front of the emblem?
#1867 31 days ago
Okay, a few small tweaks based upon some errors I saw. Review/comments appreciated before I finalize the graphic design.
#1868 31 days ago
Picked up a Last Action hero a couple weeks ago. Noticed that it was side draining like crazy. There are 2 holes above the plastic returns that look like they could have posts. Are these optional or recommended?
#1869 31 days ago
Quoted from ViperJelly:
I believe the right hand side is installed from factory, and the left side is optional - which I installed as it was killer.
#1870 31 days ago
Quoted from Kiwipinz:
Correct. I also put in the left post.
#1871 30 days ago
Quoted from bicyclenut:
I have one figure in my LAH; Benedict (in his white suite) standing next to the VUK. No trouble with the glass or the wire frame.
Is your figure bigger then the stander size?
Pictures to follow later today...
MM
OUT
#1872 30 days ago
Custom made my own mirrored game blades. Bought the vinyl off Amazon for $20. I made a template with tracing paper then cut them out. I think they came out pretty nice. However I would look for maybe some thicker vinyl next time. This stuff is .003 inch thick. All in all, for $20 and about 2 hours of my time im happy with the outcome. Here is the stuff if anyone is interested. amazon.com link »
Have you seen that stuff any thicker?
I’ve looked around and didn’t come up with anything.
#1873 30 days ago
Rivet head: 5.6mm.
#1874 30 days ago
Rivet head: 5.6mm.
Thanks. Thickness (depth) of rectangle bracket that the emblem mounts to?
#1875 30 days ago
Does anyone have a spare one of these in good condition for sale?
#1876 30 days ago
pm'd!
#1877 30 days ago
Or two? I could use one as well.
#1878 30 days ago
Quoted from madmatt1:
Yes, my Jack Slater was custom painted. I think its from a newer Terminator action figure. He's about the size of the Ghostbusters figures. The detail is awesome. I just happen to see it on eBay and grabbed it.
#1879 30 days ago
Quoted from Sohal1025:
I havent looked. I think the stuff I bought was 3ml. I bought game blades for my Family guy from Pin Graffix and they are about the same thickness as this stuff I bought from Amazon. Don't get me wrong, Im happy with how they came out, I was just saying If I could change anything Id get maybe 1ml thicker...but then again there is little for no clearance on the sides of this game. I already scratched my blades because I wasnt being careful lifting the playfield. So I made another and put it in. Hope this helps
#1880 30 days ago
Everyone, I need somebody's help, please. Since these plastics are absolute gold and nobody has responded that they have an extra one to sell, I'm working on a custom made version of one that I would be willing to sell if/when I execute.
What I need at this point are some exact measurements so that I can size the plastic. Can someone please provide the exact length and width in mm per the position of the green lines in my graphic (I have the shape and I've colored appropriately, but just don't know dimensions)?
I make my plastics out of Lexan (quite the pain, honestly, with all the cutting and shaping), which is slightly thicker but much more durable than stock plastics. I adhere the printed graphic to it so it is not painted, but the final product comes out quite nice, is extremely durable, and does not overtly stand out from the other plastics. Up to this point, I've had to adhere the graphic to the top (photo quality print with OEM photo inks & paper, then laminated with gloss vinyl), but I have some new adhesive sheets that I want to test that may allow me to adhere from the bottom side without distorting the graphics (still need to test). For reference, here is an example of two of the plastics I have created and sold for the Getaway (both plastics above the two target banks are my custom ones): https://pinside.com/pinball/forum/topic/getaway-club-dispatch-run-a-make-on-license-plate-kingpin/page/70#post-3415047
To set expectations, at this point I'm thinking I would charge $20 including postage to US. I obviously need to get one created with lots of pics before anyone commits, but thought I would throw it out there.
#1881 30 days ago
Mine is broken but at least I have both parts.
#1882 30 days ago
I am in for one!
#1883 30 days ago
Will pm tonight, after work.
#1884 30 days ago
I am in for one.
#1885 30 days ago
Cool, I PM’d you regarding a couple of items.
#1886 29 days ago
I have some extra plastics I bought off ebay. Ill look and see if this one is in with what I have tonight when I get home from work.
#1887 29 days ago
I know I seem needy, but now I need another favor from someone. I need a nice close-up, square in frame, well lit, in focus, hi-resolution photo of the Dekker sticker on the center spinner. Apparently this too is a hard find and worn out on many LAH pins. I'm going to create a reproduction and offer it for sale also. I also need to know the width and height (in mm) of the decal.
Please PM me and I'll provide my email address for you to send the photo.
#1888 29 days ago
Thank you to everyone who sent me dimensions, pics, scans, etc. on this. I now believe I have what I need to get started working on this. I have a very busy next couple of days, but will keep everyone posted on progress and availability.
#1889 29 days ago
Yes thank you, i believe mr tantrum is making these for the guy refurbing my lah pin
#1890 29 days ago
Quoted from Beaumistim:
I bet you would be 100% correct given the location of everyone (I've done a lot of work for him in the past on a variety of pins)! He does great work, and I'm happy to help him out.
FYI, I'm an OBU grad - 1990.
#1891 29 days ago
Bay Area Amusements has the spinner stickers but it only comes in the complete set that is about $45.
#1892 29 days ago
Quoted from drummermike:
Yeah, I was thinking $5 for mine and they will be gloss vinyl laminated to handle the abuse. I just need a nice pic and dimensions.
#1893 29 days ago
Well prepare, he's about to do my getaway in the next little bit after this one
#1894 29 days ago
And here is my final graphic colorized, sized, holes positioned, etc. Looks awesome printed. Now just need to work on the plastic.
#1895 29 days ago
Oh, I know, and that one is my specialty!!!
#1896 29 days ago
So, looks like my new plastic methodology is going to work great, and will allow me to adhere the graphic on the bottom instead of the top to look more like an original plastic.
So here is how it will be starting from the top layer working to the bottom:
1) Lexan sheet (plastic)
2) Adhesive sheet
3) Printed graphic
4) Clear gloss vinyl (to protect the paper graphic)
I have someone testing my graphic for size and fit tomorrow, and once that is good I will produce a prototype. FYI, we are discovering that the holes can be different lengths apart depending upon the pin, so I will be creating the left hole as a slot instead of just a circle to accommodate for this.
#1897 29 days ago
My topper emblem design is finally finished. I still need to send it off to the person whom I originally designed for to test fit, and then I will offer for sale.
As I mentioned, I will offer in 3 version including one with no holes, one with holes to fit over existing rivets, and a complete assembly to replace the current plastic and rivets.
Here is an example of the emblem itself, along with the mounting assembly with the emblem attached to it. As you can see, you simply push the two threaded rods through the existing holes (after you remove rivets) in the topper plate, and secure from back using washers and wingnuts.
Laminated emblem
Front of mount plate
Back of mount plate
Mount plate with emblem installed
#1898 29 days ago
That looks fantastic, mine has been missing the badge and I've been looking for one for quite a while. Please let me know as soon as you are ready to send me one. I'll be taking the complete assembly since my machine is missing the rivets and badge. Great work!
#1899 29 days ago
I've been kicking the tires on a LAH sitting at 2000$ for a bit now.
Can someone give me an HONEST assessment of price for LAH these days? I have a JP and am concerned that they're too damn similar to have each in a small collection.
#1900 29 days ago
I paid $2400 for mine last June. Dont regret it a bit. Great, fun, feature packed game.
$ 229.99
$ 45.00
PinSound
$ 32.00
Yorktown Parts and Equip
