(Topic ID: 67379)
Last Action Hero club, come on in!
By Matt_Rasmussen
10 years ago
  • 3,517 posts
  • 349 Pinsiders participating
  • Latest reply 6 days ago by PinballT
  • Topic is favorited by 127 Pinsiders
There are 3,517 posts in this topic. You are on page 23 of 71.
#1101 6 years ago
Quoted from StrangeSubset1:
Make sure to put an NVRAM in, best investment ever.
Installed NVRAM tonight. So glad I did. It was so easy and now I have peace of mind that my batteries are not going to leak and destroy my boards.
#1102 6 years ago
Ditto for me last week. Now to get some high scores back on there.
Quoted from Uofkgrad1990:
#1103 6 years ago
Ok, total noob question. What is the best way to raise the playfield? I pull can pull the playfield forward, but it does not want to lift up very easily. I saw that someone else had previously asked the same question, but no answer was provided for the public. I need to lift it so I can remove a scoop and look for a bulb that I believe came loose and fell into the scoop. Thanks.
#1104 6 years ago
Someone correct me if I'm wrong, since I haven't had the game very long. Your options for lifting the playfield are to either use the side support, or to lift it to vertical position and hook the bungee cord through the hook on the bottom left corner (when vertical). To do work, you're probably looking at using the bungee method. On mine, the bungee doesn't even reach. Raising the playfield is the only big flaw I've found with this game.
#1105 6 years ago
If anyone is interested (or if this is allowed): LAH is one of the free games of the month on Pinball Arcade (for Android at least, not sure about other platforms).
#1106 6 years ago
Quoted from shirkle:
Someone correct me if I'm wrong, since I haven't had the game very long. Your options for lifting the playfield are to either use the side support, or to lift it to vertical position and hook the bungee cord through the hook on the bottom left corner (when vertical). To do work, your probably looking at using the bungee method. On mine, the bungee doesn't even reach. Raising the playfield is the only big flaw I've found with this game.
Yup, same thing on my end. Have managed to hook the bungee cord. But by they then, I'm almost too wore out to work on it. LOL
#1107 6 years ago
Quoted from PinballNZ:
Hi, I want to protect the ticket from wear from the scoop ball ejection and want to put a piece of mylar on the area that wears. Question is how wide and long should I use? Should it be cut out to blend in with the black outline of the ticket ( left hand side) so that in years to come it still is fairly invisible or just do a strip say an inch and a half wide down the ticket where it will wear?
Your thoughts
Clive
Clive,
You could maybe just buy a ticket replacement overlay sold on Pinside. Would cost more, but at least it would protect the original ticket under it, and might look better and be easier on install. I bought one..looks great and is holding up perfect so far (but only been installed maybe 3 months). Can't tell it's there... easy to remove, but can't vouch for when it's been on for a long time.
#1108 6 years ago
Quoted from mbwalker:
Clive,
Old original post but...
#1109 6 years ago
Just reading that you installed the ticket. I bought one but have been hesitant to install it yet. Any tips on installing it? What was you experience installing?
Clive,
#1110 6 years ago
Quoted from jedi42:
Jedi,
Ha...I did the same thing. It sat there for at least a couple of weeks while I pondered 'how to do it perfectly'...as curse of mine.
Do the obvious - clean of the current ticket area. I believe Mike (the seller) recommended cutting off excess paper to make it easier to install. I don't remember if I trimed all sides or just one, likely doesn't make much diff. Was very simple. I used the long top side to adhere first since it would result in less alignment error. And attach just a small amount of the edge first in case it goes awry and flatten it (like with a credit card or you fingers) as you adhere more to make sure there are no bubbles. Took maybe 30 secs top. Looks perfect. Some people have mentioned it can be peeled off if it's not going on straight, but I didn't have that problem. I did set it on top with the paper attached first to see how the edges aligned.
Your next post will probably be "Yeah, that was easy!" Post how it goes!
#1111 6 years ago
I second that. Tough to get in, take a break from work after you get it in.
#1112 6 years ago
Can someone post a pic of how the magnets are wired, connectors and whatnot? Mine is...definitely not correct, and magnets are pretty weak because there's no way they're getting proper amount of current. I just need to see a correct setup so I can make new molex connectors. No clue if the three fuses near them is factory or not. It looks like it but the way they're wired is...um...lol.
#1113 6 years ago
Quoted from Frax:
Hey Frax,
Here you go. If you want, PM me and I'll shoot you a higher res pix, or take others as needed.
Let me know if this OK, this is just one I had...but it is of the magnets.
Mark
#1114 6 years ago
Wow that is the SAME ghetto setup mine has, only the solder job is crap. I can't believe they just spliced the wires like that. UGH. I guess I need to ohm out these magnets and see if they're in normal range or not because the action from them is pretty sorry, even after I resoldered that splice.
#1115 6 years ago
Well, I seem to have found what's causing the issue with odd ball ending and whatnot...the right side crane switch is shot....it's mushy and doesn't spring back open when the crane moves to the right like it should, which causes all kinds of fun things, like automatically losing your ball if you start Super Crane. I turned the crane off last night and was able to play an otherwise perfect game. Virtual locks actually work on this game, which is nice, because the release from the tar pit is questionable at best.
Crane limit switches are listed as 180-5093-00 but I can't find them in stock anywhere. >=| Anyone know of another viable replacement part? I haven't had much luck taking off blades from one microswitch and putting them on another one.
#1116 6 years ago
The blades pry off just fine with a tiny eyeglasses flat blade driver
#1117 6 years ago
Think I have one sitting around somewhere..I'll give it a shot. Crane is disabled right now anyways so taking it off ain't gonna matter.
#1118 6 years ago
Had my LAH for almost a month now. Cleaned and LEDs in. Was a reimport from France at some point, so had some creative wiring I had to sort through, but it's 100% now after some heavy cleaning/polishing. Would be a rad game to see a color dmd in!
Anyone know the changes in the .112 code over the .106?
After and before pics.
E95EE92C-0EEB-4757-8B43-01135F0C2104 (resized).jpegE95EE92C-0EEB-4757-8B43-01135F0C2104 (resized).jpeg
706CBDFD-51E6-4956-806D-DA5C43788A3E (resized).jpeg706CBDFD-51E6-4956-806D-DA5C43788A3E (resized).jpeg
3A5A41BB-BACC-4F25-8889-4A564F70FB6D (resized).jpeg3A5A41BB-BACC-4F25-8889-4A564F70FB6D (resized).jpeg
266E723B-4D65-4C9E-B8EA-DE9FA7E74154 (resized).jpeg266E723B-4D65-4C9E-B8EA-DE9FA7E74154 (resized).jpeg
E1BD3C12-A31F-46A0-932C-8A4FA6E6A4B1 (resized).jpegE1BD3C12-A31F-46A0-932C-8A4FA6E6A4B1 (resized).jpeg
#1119 6 years ago
Quoted from ChrisRAD:
Details here
https://sites.google.com/site/lahpinballmod/
#1120 6 years ago
I have a LAH A1.06 with CPU 1.05. Today while playing the music stopped and the dialog would keep repeating "I'll be back". The game play is OK when this is happening. Anyone know what this is all about? Thanks.
#1121 6 years ago
There was an amazing looking Last Action Hero at the Texas pinball festival today. Powder coated wire form ramps and pin Stadium lighting.
#1122 6 years ago
Quoted from Butch2099:
I loved that you could change the lights in the pin stadium lighting with a phone app, super cool mod
#1123 6 years ago
Quoted from drummermike:
We had the same problem once, I believe the game had developed an issue and had gotten 'confused' (for lack of a better term). I shut the game off, seated some connectors as a precaution, and the problem apparently was resolved after powering back up. Wish I could add more details, but I can't. Not sure if it was hardware related or maybe a software bug (we are running the latest code).
Did you simply try shutting it off and turn it back on?
#1124 6 years ago
Shutting it off must have worked. It is working now! Thanks.
#1125 6 years ago
Anyone know what keeps the left side of the Danger sign in place? Mine seems to dangling. There is a bracket there behind it with a semicircle notch in it, doesn't seem to be broke or bent. I did notice a nylon bearing on the rod that supports the Danger sign (but not snapped into the bracket). So does the nylon bearing simply fit in the left bracket? If so, doesn't seem like there's anything really holding it in place, no?
I've tried countless searches on the web, but I just can't seem to find any info on this part of the game.
Thanks ahead of time.
#1126 6 years ago
It looks like there should be a plastic bushing in that spot. The frame of the assembly (which runs flat across the playfield under the assembly) has a bend off the end that extends behind the danger bar switch and clips into that bushing. I suspect the end of that metal bracket is broken off of you assembly. See pictures.
#1127 6 years ago
Thanks for the pixs Caker, that helped a lot.
I think the rod just popped out of the bracket and then the nylon bushing slid on the rod. The bracket appears to be OK. Earlier, I suspected that's what happened, and I moved the bushing back into place and pushed it in the semicircle part of the bracket on the left. Seems kind of like a jinky way to secure it tho, thinking maybe something more substantial was missing. But I guess it only gets bashed from the the front, so maybe it's enough. I'll give it a test drive tonight and see what happens. Here's mine afterwards - looks like yours.
I think it's been like this since I got LAH about 6 months ago.20180325_164513 (resized).jpg20180325_164513 (resized).jpg
#1128 6 years ago
What do you think the chances are that someone has a NIB LAH sitting around? You see it with other titles. PM me if you have one..Lol
#1129 6 years ago
I wonder what that would go for
#1130 6 years ago
Those speaker lights would look much better if the painted grills were placed behind the light frames.
02 grills behind light frames (resized).jpg02 grills behind light frames (resized).jpg
#1131 6 years ago
While playing LAH today, the music stopped as it has done before. This time the game play was OK and Arnold was not saying "I'll be back". Is the CPU going?
#1132 6 years ago
Check the 12v to your sound board. Is there a certain point when the music stops? (can you predict when it will occur?)
#1133 6 years ago
Really simple answer...just try shutting it off and back on again.
#1134 6 years ago
I did the on off thing. It worked that day then later it happened again. It occurs randomly. I will check the voltage. Thanks.
#1135 6 years ago
Quoted from TheCapn:
I looked at the sound board and I am not sure were to check for voltage. My power board is a Rottendog. I put plastic washers in the sound board screw mounts a while back to help with the buzz.
#1136 6 years ago
Hi Drummer,
Do you have some basic electronic equipment like a meter, or ideally a scope?
No experience w/RottenDog...but I sure see a lot of negative comments about their power supplies and compatibility. Not sure if it's just people messing things up, or if they really are the culprit...
#1137 6 years ago
I have a multi meter but I am not sure were to test on the board. I do not want to fry it!
#1138 6 years ago
I have a Rottendog in my CV for years and it works great. No more resets during the game. I put Raspberries in TZ and TAF to stop the resets with the original boards.
#1139 6 years ago
Rottendog and Xpin PSUs can sometimes have issues with 12v line going to the soundboard. Especially when the game starts drawing more current. i.e. Multiball. I will show you how I resolved my problem with my sound issue on this game in the future.
There is also a chance that you may just have a loose connection somewhere and when your shaker motor starts shaking - the weak connection is amplified. So, you can try disabling your shaker motor in settings, reseat all connections to the boards and see if that changes anything too.
#1140 6 years ago
I broke down & bought the NOS clearcoated playfield that was in the marketplace. It's going to be my 1st playfield swap. Does anyone have a NOS plastic set to sell me or know where I can get one? I have at least 1 broken plastic on mine (left rear corner), Any tips are appreciated!
#1141 6 years ago
Thanks. Sounds like a plan.
#1142 6 years ago
Are there any mods (i.e. Pinsound, extra lights) installed in the game on the +12V line? Not familiar w/the RottenDog power supply, but I suspect there is a +12V test point that you can monitor the voltage (as Capn sort of alluded to). I've seen some discussions where the +12V is unregulated and drops too low - but just repeating what I read...no personal experience.
Take a look and see if any of this applies: https://pinside.com/pinball/forum/topic/data-east-gnr-12v-drops-low-power-supply-or
Is this your RottenDog power supply?: http://rottendog.us/DPS004.html
#1143 6 years ago
That is the RD board that I have. I think it is 3 or 4 years old. I have no mods on this LAH. I only replaced the DMD and the power board when they failed. I tested the voltage on the RD board at the three round areas. The voltage was 5, 12 and -12 as it should be. I played today and it was OK again. I reset all the connectors. Still not sure why the music dropped out.
My CV Rottendog board is 3 years old and I have had no issues. Thanks.
#1144 6 years ago
Chances are you need to somehow stayed attached to the 12V test point to see if the voltage dips during play. Ideally, that's what a oscilloscope is for...it shows voltage vs. time - so you can see the voltage dips (or peaks) over time. It does appear the 12V is unregulated. That might be the culprit, if it's really the 12V causing the issue.
#1145 6 years ago
In case of last resort. This will solve your voltage drop issue. Even before my Pinsound I had issues with sound dropping out. Haven't had any issues since this fix.
#1146 6 years ago
Does the PinSound stop the DE buzz? Why did you do the PinSound? Cost?
#1147 6 years ago
Getting an LED DMD to not use the HV line will eliminate the DE buzz. Pinsound is $350+. I bought it during a show so I got it at a discounted rate. I use pinsound because I like having a better quality soundtrack. I use the same music the game has, but instead of the MIDI quality I have the MP3 quality of the actual tracks. Plus, I added some other nice tracks to the mix. Those that played it at Texas Pinball Festival should be able to agree that the soundtrack is very nice.
#1148 6 years ago
Hey guys, just wondering what might cause the game to allow you to start modes without going up the ramp to turn off the Dynamite light? It has only just started happening!?
#1149 6 years ago
Quoted from Kiwipinz:
When the ball rolls over either of your inlanes it will give you temporary access to dynamite features. Instead of it being LIT it will blink for few seconds but if you nail the scoop while its blinking the feature will activate.
#1150 6 years ago
Well that makes sense. Awesome, thanks!!
Gweem's Mods
$ 39.99
Mitchell Lighting
Professor Pinball
$ 18.95
$ 12.00
Tools
Nezzy's Pinball Prints
Slap Save Creations
$ 1.29
Daddio's 3D Printed Mods
$ 27.95
$ 32.00
$ 18.95
5,000 (OBO)
Lake Charles, LA
PinSound
3,500
York, SC
$ 18.95
$ 5.00
This page was printed from https://pinside.com/pinball/forum/topic/last-action-hero-club-come-on-in/page/23 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
