Perfect!
Thanks capn
Hello guys I was trying to access to the underside playfield but i'm not able to put it full raised up and under rest (on the backbox).
How i'm supposed to do it on this data east pin? It is so easy on Bally/williams!
Quoted from Pesmerga:Hello guys I was trying to access to the underside playfield but i'm not able to put it full raised up and under rest (on the backbox).
once you lift the PF up about a foot you should be able to pull the PF towards you which will allow it to slide on the rails and then you can make it up upright (Requires some tug). If you are still unable then you may want to make sure your cables are not snagged on anything. Sometimes the cable covers (black shielding) is mounted to the backbox by a screw and zip tie. Make sure you have enough slack.
Quoted from kba78:Hey everyone, I am trying to put together a last action and someone cut a connector of the playfield harness. Could someone post a picture of connector j-8 on the ppb. It's in the lowest row of connectors behind the speaker panel. Strangely, the schematic is written for Jurassic park and doesn't give all the same wires.
Any help would be much appreciated
Did you check the Tech Chart?
http://www.pinballrebel.com/pinball/cards/Tech_Charts/Data_East_Last_Action_Hero_Tech_Chart.pdf
All the wires match the image that's posted here.
Quoted from TheCapn:once you lift the PF up about a foot you should be able to pull the PF towards you which will allow it to slide on the rails and then you can make it up upright (Requires some tug).
When putting the playfield back, I slightly lift the back end up
in order to get over the "hump" of the side rails.
( clasp the back playfield by reaching around over the back wall )
Quoted from TheCapn:once you lift the PF up about a foot you should be able to pull the PF towards you which will allow it to slide on the rails and then you can make it up upright (Requires some tug). If you are still unable then you may want to make sure your cables are not snagged on anything. Sometimes the cable covers (black shielding) is mounted to the backbox by a screw and zip tie. Make sure you have enough slack.
I've tried to do like this but it seems to be blocked in the lower part by the pieces of wood on the cabinet side. Also I don't see any blocking system like in bally Williams. What would prevent the pf to slide back down??
Quoted from Pesmerga:I've tried to do like this but it seems to be blocked in the lower part by the pieces of wood on the cabinet side. Also I don't see any blocking system like in bally Williams. What would prevent the pf to slide back down??
Take a picture, and show.
Quoted from vec-tor:When putting the playfield back, I slightly lift the back end up
I only lift the back end when putting the PF back in.
Yes, we would like to see some pics or even a video to assist further.
LOL, just found out that the light bulb schedule in the original maintenance manual are pretty much incorrect. I had found a couple light bulbs out and thinking I would be smart I looked in the manual and ordered a bunch of #44 since they were listed as such. Came in the mail, and I was eager to replace them....should have looked first. They are #555, no I have to wait another 2 days for new lights ;-(.
Quoted from StrangeSubset1:I had found a couple light bulbs out and thinking I would be smart I looked in the manual and ordered a bunch of #44 since they were listed as such.
Pinball tip 101, never trust the game manual. Fiscally check the part
then check again and verify.
Anyone be able to post an up close picture or scan of the speaker grilles and emblem in the middle of the topper. It's the last few things I need to get this thing back together (I think?)
Thanks again for the help guys
There should be a bungie on the bottom of the cabinet that keeps it upright. I don't believe it is meant to rest all the way on the backbox.
Quoted from kba78:Anyone be able to post an up close picture or scan of the speaker grilles and emblem in the middle of the topper. It's the last few things I need to get this thing back together (I think?)
Will shoot some pictures tomorrow night. You need it from the backside I assume?
Actually need pictures of the front were the tickets are on the grills. Gonna try to make a stencil but can find a close enough picture
Quoted from kba78:Will shoot some pictures tomorrow night. You need it from the backside I assume?
Awesome, thanks!!! Those should work. Can you post one of the emblem in the middle of the topper too? Thanks for the help
Quoted from kba78:Awesome, thanks!!! Those should work. Can you post one of the emblem in the middle of the topper too? Thanks for the help
I might have to take another one in daylight tomorrow.
Thanks strangesubset1. If you can't get one with out shadows, then I will try to make it work.
Thanks much
Quoted from kba78:Thanks strangesubset1. If you can't get one with out shadows, then I will try to make it work.
Thanks much
This is the best I can do. Sorry. Mine is not the best anymore
Hi guys! Sorry, I've been busy in these days but I promise I will send you a picture as soon as I can! Thank you very much for your help!!
I thought I had read this here somewhere, but after rereading the entire thread and 772 post, I can't seem to find it anymore.
Here is my issue. The ball sometimes gets stuck at the VUK on the top right. The one that shoots it onto the ramp or crane if in place.
The coil works, tests fine and probably 2-3 times fires fine, but 1 out of 3 times it simply sits there and does nothing. This seems to happen more often in multi ball mode. I have to wait an easy 20 seconds for the ball to go into missing ball mode and fire all the coils for it to be ejected. This is particular bothersome in multi ball mode, since the VUK gets blocked.
Any help is appreciated.
Quoted from StrangeSubset1:I thought I had read this here somewhere, but after rereading the entire thread and 772 post, I can't seem to find it anymore.
I would check the solder joints on the switch. May not have a good connection. When multiball is active so is your shaker motor which can vibrate any loose connection you have in the game.
Quoted from TheCapn:I would check the solder joints on the switch. May not have a good connection. When multiball is active so is your shaker motor which can vibrate any loose connection you have in the game.
Thanks. Will check tomorrow. That sounds logical. Found a couple bad solder joint before, just did not venture that far back under the playfield. Makes sense though, now that my shaker is running again.
I have a couple of questions as someone who is just getting their machine out back together.
Did any of you leave the short rubber sleeves off your posts and just run the rubber rings on them?
Do any of you have a picture handy of the VUK switch? I can feel the end of the switch but there isn't anything in the hole for the ball to trigger.
I have a couple more things to address and then I can put the ramp and wireforms back on and start playing it.
Quoted from kba78:Just happened to have a mechanism handy
I appreciate that! Thanks!
That is what I was hoping to see. I have that circular wire in my misc cabinet treasures. Just need to reattach.
StrangeSubset1 If problem continues, you might want to replace
with upgraded part #180-5116-01 "fork tongue" microswitch assembly.
Anyone able to give a me a high res scan of the plastic that covers the ripper coil? Coil burnt up and took the plastic with it. Would like to make a new one made.
Quoted from TheCapn:Just ordered a rottendog MPU for my LAH. Anyone else have one? Looking for some reviews.
I just got one so I can't say anything except the game plays normally, as far as I can tell.
Finished the last thing on my to do list: install new drops and put on the new crane lettering. I'm sure I'll find something else to tinker with but for now it is done. Huge thank you to @caker137, I've been playing with the new firmware since I got the machine. It really improves so many modes and the real ball save is so needed for me.
Quoted from TheCapn:Anyone able to give a me a high res scan of the plastic that covers the ripper coil? Coil burnt up and took the plastic with it. Would like to make a new one made.
If nobody gets you one by Saturday I will. Can't get to it right now.
Quoted from StrangeSubset1:If nobody gets you one by Saturday I will. Can't get to it right now.
Thanks. Much appreciated.
Also, my rottendog MPU for LAH is working great, everyone.
Question for those who have had the game for a while: I see it mentioned that it features songs from the soundtrack but I haven't recognized any version of them. When do they play?
you may need to go into your settings under the adjustments. There is an option to turn down the background music.
Quoted from TheCapn:you may need to go into your settings under the adjustments. There is an option to turn down the background music.
Turn down? I would assume i have to turn it up, don't I?
Quoted from TheCapn:This is the main theme as you play.
I knew that.
Thanks! I am embarrassed to admit but I never heard that song as Big Guns until I listened to them both back to back.
If anybody is looking for an alternative translite for their LAH, I now have this one available which actually has the correct logo text matching the cabinet artwork:
Message me if interested, or it'll be on the Retro Refurbs website next week.
Pete
Retro Refurbs
Quoted from StrangeSubset1:Turn down? I would assume i have to turn it up, don't I?
either way, yea. Did that solve your issue though?
This page was printed from https://pinside.com/pinball/forum/topic/last-action-hero-club-come-on-in/page/16 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
