(Topic ID: 269782)
Laser Wars - boots in to settings and automatically runs through them
By crazi
  • 17 posts
  • 4 Pinsiders participating
  • Latest reply 3 years ago by barakandl
    #1 3 years ago
    I'm trying to help someone out with their Laser Wars CPU.
    It boots right in to the settings menu and "automatically runs through them" at high speed - in advance mode as far as I can tell - and just keeps running through them over and over again WEIRD!!! It's like you have your finger on the "advance" switch and never let go...
    1) Changed processor - no difference
    2) Changed ram - no difference
    3) Checked inputs/outputs at 7402 at 1F (Nor gates from the test switches on the door). Inputs are all high and outputs low as expected. Pin 8&9 High and Pin10 Low.... Pin 5&6 High and Pin4 Low (all correct)
    4) Game Rom - I have burned 2x new ROM's 27256 using the code from IPDB but neither will boot the board? Just hangs and crashes on boot. This confuses me! as the original ROM boots in to this issue so I really wanted to change the Game Rom. I'm using M27C256B. They burn and verify but just won't boot the board?? I loaded the IPDB code in to the buffer and "verified" the original game rom and it verified ok. So the IPDB code looks right... baffled
    HELP?
    Also - I do not have a "laser war" so for testing I am just connecting power and displays on the CPU on one of my DE Machines to see the fault
    #2 3 years ago
    Quoted from crazi:
    HELP?
    Check that the two connectors of the left side have not been swapped.
    #3 3 years ago
    Quoted from crazi:
    Next component up is a PIA.... any corrosion around any of these traces?
    #4 3 years ago
    Connectors are good...and still does it with the connectors off
    No battery corrosion...
    Are you meaning the Displays PIA? What bothers me though is that the displays are working fine...
    #5 3 years ago
    No, the outputs of the chips you measured go directly to a PIA's. Since you have the correct information coming in/out of the 7402s, the next component in the chain is a PIA. Those 7402's aren't connected directly the microprocessor.
    #6 3 years ago
    Yes the outputs go directly to the Display PIA CA1 & CB1 and the displays are working fine
    #7 3 years ago
    Any reason why a M27C256B EPROM would not work on Laser Wars?
    As mentioned I have burned and verified 2x and both won't boot the board. I really want to swap the Game Rom to see if it fixes this issue...
    #8 3 years ago
    Video of the issue
    https://drive.google.com/open?id=17W1QT6gafIrlef0FMW83ueMKGLVHFDBJ
    Boots right in to the settings then runs through them continuously
    #9 3 years ago
    If I read the schematics correctly the outputs of those 7402 go into *inputs* of the PIA. The displays working don't factor into that - different port. It's just the next item up.
    If you have chips verifying as good I doubt it's going to be the eprom although that is not unprecedented - I had a sound eprom on pinbot that verified all day on 2 different brands of burners and it was still bad.
    #10 3 years ago
    You reckon I should change the PIA?
    It's just very strange that it won't boot on multiple new eproms - only the original. I have that voice telling me the fault could be a game code glitch. Wanted to factor that out first by swapping the eprom before starting to change other components on the board
    #11 3 years ago
    Replaced the Display PIA 11b - no difference
    Not sure where to next other than trying to get another eprom to boot the board...
    Thoughts???
    #12 3 years ago
    Took 2x known working (test roms I have for a different game) and wiped them clean. Burned Laser War code Ver: 1 on to both of them. Both of them won't boot the board either yet the original eprom boots the board....WTF???
    #13 3 years ago
    It is probably not the EPROM.
    Williams 3-6 games use a similar diag button input system with a 7402. If those games its possible to have a fault with that chip that makes the audits scroll constantly. In those games it is usually from the nearby battery holder rotting out the path to ground for the chip. If you have a logic probe or even DMM should be able to see activity thru the 7402 when the test buttons are pushed held down.
    #14 3 years ago
    Thanks Andrew - will take a look
    Couldn't get new 27256 eproms to work. So installed J5 (removed J4) and copied the code to a 27512 and doubled up the code. That boots! (still got the exact same scrolling issue though)
    At least I know in theory it's not the Game eprom. So moving on. Will just change the 7402 even though it seems to measuring fine but out of options now.
    Still scratching my head why the 27256's wouldn't work...
    #15 3 years ago
    Replaced the 7402 but no difference
    Burned a test IC from Marco on a 27512. It's flashing away. The Lamp PIA Pin2-17 are constant 3.8v whereas the other PIA's are fluctuation 0v - 5v - 0v (excluding the switch PIA which is correct).
    Am I right in thinking that Lamp PIA 11D seems dodgy??? and would/could that cause the scrolling issue on settings after boot?
    #16 3 years ago
    Replaced the lamp PIA and it's now in attract mode!!! WOOHOO
    #17 3 years ago
    Quoted from crazi:
    nice!
    that PIA is probably the one that diag buttons go back too.
    This page was printed from https://pinside.com/pinball/forum/topic/laser-wars-boots-in-to-settings-and-automatically-runs-through-them- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
