A more detailed post of where things are at now:
I have a Laser War with a version 3 mpu in it. The game is fully playable. All sounds, lights, and solenoids are working properly and playing it is a blast.
There is nothing displayed on any of the displays though.
I just rebuilt the HV section on the power supply and have proper voltage on the power supply at connector cn5 for the displays, and on all 5 of the connector pins (pin 2 and 12) for each of the displays attach to it. 3 of the displays (player 3,4, and the ball/credit display) were tested in my Black Knight and all work great. I cannot test the 2 DE displays for player 1 and 2, but have tried with them plugged in and unplugged with no difference. I have the extra pins added at cn3 on the mpu for the ball/credit display as well.
There is no chip at B5.
What looks to be the original Laser War game rom chip with original factory lable is installed at C5.
There is a 6264 installed at D5.
Do I need to burn a different game rom chip to work with the 6264, or can I just swap it out for a 6116 as per the original version 1 mpu (I think that's correct)?
Someone was messing around with the jumpers on this board for some reason and had a couple of them crossed j4/5 each had one end of a jumper attached on each one, as did j7a/b. J6b was installed but not j5b.
I don't know if that would damage anything or just send game information or partial information to the correct/wrong place.
Currently I have the jumpers installed as follows:
J1B, J3, J5, J5A, J6A, J7A, J8.
The following are NOT installed:
J1A, J2, J4, J5B, J6B, J7B
With the original game rom at C5, is having J5 and J7A installed correct?
Will that original game rom work correctly with the 6264 installed at D5 or do I need to install a 6116?
I don't know what the original game rom is as far as what type of chip. Do I need to burn a new game rom on a different chip to have it work with the 6264 currently installed?
Just trying to clear up some confusion on this board and hopefully that will get the displays to display information!
If not, then I suppose I need to look into something else on the mpu maybe not putting out signals to the displays? I would think everything should be good through the PIA though since the power up lights are correct every time.....
Thanks in advance!
**UPDATE**
I have a 27256 at 5C, the original Laser War game rom. Changed jumper j5 to j4 to be correct with this rom.
Still no displays.
I have a probe and was going to connect it to the ground/+5 test points on the mpu and check for signals coming out of the PIA. Are there certain pins I need to check or all of them? I think they should all be "low" and none of them "high" correct?
