Very nice. I highly recommend color LEDs for this game, for the inserts at least.
What are some serial numbers and build dates people have on their games? It says on the info page that the game was made in 1987-88, but mine has a build date of 1990 on it.
I've recently started with the creation of Tech Charts for Data East games.
Laser War is the first in the list.
It is much like the Williams System 11 games, but names for the various connectors are changed.
Also the transistor designations are different than the Williams System.
Can you guys help me with checking the file for mistakes?
Here is a copy of the file for you to look at.
Peter
www.inkochnito.nl
Welcome warrior, energizing, Fire and return to blue/red/yellow, return to base, laser war, explosion, last ball good luck, and shoot the ion cannon...plus laughing. I think that covers the sound call-outs.
I just recently set up my lazer war and am having trouble with airballs when the left ramp is shot. My flippers are pretty strong and have thought about enclosing the area in plastic but am looking for easier suggestions. thanks
Quoted from out_of_order:I just recently set up my lazer war and am having trouble with airballs when the left ramp is shot. My flippers are pretty strong and have thought about enclosing the area in plastic but am looking for easier suggestions. thanks
How's it airballing? Just by going up the ramp? Or hitting one of the posts at the entrance of the ramp?
Quoted from out_of_order:Yes, up the ramp.
I am thinking of putting plexiglass there, but it may not look to good.
Sounds like you might have incorrect coils. I had strong ones that would give me lots of air balls. Put in the proper coils, and flippers were still strong, but no more air balls.
If anyone is looking or knows someone who is looking for a Laser War, I am going to be selling mine. It's in excellent physical shape, including the playfield and I have extra NOS parts for it like the ramp and spinner decals and manual. All displays work and it boots up and goes into attract mode, but I can't start up a game or get into test mode. Borygard fixed the main board so I don't think it is a board issue. I am getting a new game and one has to leave so one can come in so this one is on the chopping block. I'm asking $650 for it.
Quoted from blowback1976:I always thought it was "damn I'm hit!"......
Quoted from out_of_order:thanks, i wll check out what coils are in there. Do you know what size coils you have in your LW ?
I'll have to check. I don't have it anymore, but I remember some printed material had the incorrect coils listed. I'm still in contact with the guy that bought mine, so I'll find out in the next day or so for you.
Quoted from out_of_order:The coils in mine are "black beast" 0409-33 0905000-00
I think those came from the factory on mine
Sounds right. Here's what I installed when my flippers died. The new ones are FL-11630.
Is that the same strength coil ? I looked at Marco and they have a 22-750 as a replacement
I think a weaker coil would solve this problem.
Quoted from out_of_order:Is that the same strength coil ? I looked at Marco and they have a 22-750 as a replacement
I need to check the printed materials, as I know Laser War did have different coils listed at one point. This chart may help: http://www.pinballmedic.net/coil_chart.html
But the FL's were of equal strength, and work fine.
Happy to join this club! LW has always been one my favorite.
I am in the process of restoring mine (I had 2 examples few months ago, kept the best of the pair then sold one).
Mylar removed, touch ups + clear coat with spraymax 2K.
Lot of work under and top of playfield, almost done but now waiting for a LED order from comet.
About the flippers coils: I strongly suggest to not replace with the original DE coils, too strong!!! Will cause damage and air balls!! I've owned it for 2-3 years now, the Williams FL11630 are perfect for the game, I would suggest to add the 2.2Kohm capacitors for the EOS.
I also have on hands: NOS chromed ramp, NOS plastics (back panel already installed on the pics with colored flasher domes).
I figured I'd chime in here now that I finally got around to taking a few pics of my Laser War. I absolutely love this game. I haven't touched anything on it yet, LED's really do make these look awesome but mine is so fresh, new and clean feeling I've decided to keep it all original for now.
Quoted from woody24:But looks like if you wanted to take out the ramp, you have to lift the playfield out of the cabinet. I tried to remove the ramp, and it doesn't come out when its in the cabinet.
I had to remove my ramp to put in a new yellow flasher in the upper right corner of the ramp. Took me a minute to figure it out but it goes like this - remove the wireframe ball return from the ion cannon ramp - it just pulls straight down towards the flippers out of the ramp once the nuts are off. Then on the right side of the ramp, to the left of the yellow base lane, there's 2 screws on a black metal frame piece holding the ramp you can get to. Take those out, and then under the little flap at the ramp entrance, there's a 3rd screw. Remove that and the ramp should come out easy without removing the playfield.
Quoted from sevenrites:I had to remove my ramp to put in a new yellow flasher in the upper right corner of the ramp. Took me a minute to figure it out but it goes like this - remove the wireframe ball return from the ion cannon ramp - it just pulls straight down towards the flippers out of the ramp once the nuts are off. Then on the right side of the ramp, to the left of the yellow base lane, there's 2 screws on a black metal frame piece holding the ramp you can get to. Take those out, and then under the little flap at the ramp entrance, there's a 3rd screw. Remove that and the ramp should come out easy without removing the playfield.
Very nice. Very clean. Kinda wish I still had mine to play with. But happy with my JP.
I think I misspoke with the ramp. I actually meant the launcher wireform that loops around behind the playfield. Were you able to get that out without taking out the playfield?
Quoted from woody24:I actually meant the launcher wireform that loops around behind the playfield. Were you able to get that out without taking out the playfield?
The wireform that loops around the back, I have not yet touched. I was behind it to do a flasher but that's it. This game was so clean when I got it, I did not feel the need to tear it down. I didn't even want to put my hands on a bulb socket without wearing white gloves. It was very well cared for its entire life.
Quoted from Chitownpinball:Friend of mine has a LW, he says the red base take a long time to kick the ball out of the saucer. Any insight into what he needs to repair or adjust?
when I shopped mine out, that kickout seems to attract a lot of crap, wax, dirt etc, my switch was dirty as hell, thats my guess, also, an led, acorn nut, etc that falls in that kickout could be preventing the ball from sitting in there flush....
Quoted from ZEN:when I shopped mine out, that kickout seems to attract a lot of crap, wax, dirt etc, my switch was dirty as hell, thats my guess, also, an led, acorn nut, etc that falls in that kickout could be preventing the ball from sitting in there flush....
cool, thanks. ill pass that along.
Probably the sensitivity of the switch in the saucer. That's my old machine isn't it? I worked on that switch once, and thought I got it figured out. Couple things I would try. Make sure there's no oxidation between contacts. Take a thin piece of cardboard, or textured business card and rub between the contacts. Then maybe tighten the spacing between the gap of the leaf switch.
Just a slight nudge would get it to see the ball when it acted up for me. So that just told me that the contact is so close to working. Some minor tweaks should better fix it.
Just joined the Club! This game is awesome. I can't tell if it's really hard, or my pin-guy app is mis-calibrated, will figure that out later. Woody, I picked it up from ft. wayne and was trying to figure out if it was the one you sold on here a while back.
Quoted from woody24:Probably the sensitivity of the switch in the saucer. That's my old machine isn't it? I worked on that switch once, and thought I got it figured out. Couple things I would try. Make sure there's no oxidation between contacts. Take a thin piece of cardboard, or textured business card and rub between the contacts. Then maybe tighten the spacing between the gap of the leaf switch.
Indeed it is your machine. I will pass this along as well.
I had never even seen this pin before INDISC / Arcade Expo, and now it's on my list of "gotta buy someday"! It's so much fun! But to hell with that left outlane.
Data East really made some great machines (but not Torpedo Alley. Eff that game in its face)!
Quoted from Cornelius:I had never even seen this pin before INDISC / Arcade Expo, and now it's on my list of "gotta buy someday"! It's so much fun! But to hell with that left outlane.
Disagree. Torpedo Alley has an a very unique design, and some great long shots. Plus the translite is all kinds of nice.
And I'm IN! Very fun machine to say the least.. So much fun that I haven't done my usual shop right when I get a pin, Laser War can not have down time.. - Everybody should own 2!
Now to find a promo plastic for the key chain, and spend some time figuring out how to remake the OEM topper.
Quoted from danczaz:Thanks to Harvs for hooking me up with everything on my wish list!
Anything for a Laser War owner!
Quoted from Harvs:spend some time figuring out how to remake the OEM topper
Yes, please! Someone out there has one. I'd prefer an original but a well done remake to spec would serve the purpose. I can't even find schematics / blueprints on it. Gary Stern could probably help, but he's probably too busy with the new Stern & I suspect he could care less about the games that got them to this point even though there's a huge potential market wanting access to some coveted Data East and Sega pinball archives and history he probably holds the keys to.
Quoted from danczaz:This OEM topper on flyer?
Yep, the OEM one in the flyer is what I'm after.
I have an idea on what the topper did.., that's the easy part. Molding the topper itself is what I have to figure out. For now I just have a Laser War plexi that I made, better than nothing (I think). I will also be making the pops, spins and flipper 'intercooled' decals in chrome/red, like OEM.
And don't tell anyone.., but I just committed to buying another Laser War in Minty condition. My goal is to fill my game room with only Laser War pins. Ha!
Made the pop stickers. They are chrome and have the head cutout vs the head being red, bulb light shines through nicely (I put white under the pop to diffuse my LED, but looks good both ways). I can have these made if anyone wants them.
Also have the cheesy adhesive topper print and 'intercooled' stickers in white font or black font for the flips.
PM me if interested.
Quoted from Harvs:I have an idea on what the topper did.., that's the easy part. Molding the topper itself is what I have to figure out. For now I just have a Laser War plexi that I made, better than nothing (I think). I will also be making the pops, spins and flipper 'intercooled' decals in chrome/red, like OEM.
Your next Laser War is on it's way to you now! She will be missed. I threw two of the custom Laser War keychains I had made for it in as well, one for both your games.
Also, I forgot I had these. I have a couple brand new ramp flaps from Cliffy that were custom made by him using my original ramp flap as a mold. I sold my game, so I don't need them anymore. They both are brand new, never used, with the protective plastic film still on each of them. If anyone wants them, I'd do $15 shipped each. Let me know.
Harvs, please share pics of your minty one when you get it... I consider mine minty as well and think I already shared a few pics. I'm actively trying to find a nicer example just to see how mine compares.
Quoted from LesManley:I have a couple brand new ramp flaps from Cliffy
The cliffy ramp flaps look good, his products usually seem to be better quality and durability than OEM.
Quoted from Harvs:Made the pop stickers.
Quoted from Harvs:and 'intercooled' stickers
The stickers look great too. I don't need anything on my game at all, if I did I'd hit you up. It's good to know someone is taking care of these things though!
My biggest concern is I'm afraid to break the original chrome ramp. I have to keep my game raised pretty high in the back to weaken the flipper impact. I'm tempted to buy the black ramp and put it on and save the chrome one. But my Laser War has virtually never been apart, all factory stock still. It's probably had less than 1200 plays ever.
Quoted from LesManley:Your next Laser War is on it's way to you now! She will be missed. I threw two of the custom Laser War keychains I had made for it in as well, one for both your games.
Also, I forgot I had these. I have a couple brand new ramp flaps from Cliffy that were custom made by him using my original ramp flap as a mold. I sold my game, so I don't need them anymore. They both are brand new, never used, with the protective plastic film still on each of them. If anyone wants them, I'd do $15 shipped each. Let me know.!!2_(resized).jpg
Yep, gonna be heading out shortly to grab that minty Laser War AND a minty Time Machine! Just need a Secret Service now to complete the trio!
Quoted from sevenrites:Harvs, please share pics of your minty one when you get it... I consider mine minty as well and think I already shared a few pics. I'm actively trying to find a nicer example just to see how mine compares.
Will take some pics once its home and in the game room. Thanks!
I did put the FL11630 coils on the one I have now.., less air balls etc. Might want to give it a try and see if you like the feel.
* I posted this yesterday. Could anyone answer if some of the flasher resistors get hot while in attract? I guess I'll have my 2nd one home at about 5pm today, so can find out later.
https://pinside.com/pinball/forum/topic/flasher-resistors-some-hot-some-not-in-attract-mode
Quoted from Harvs:Will take some pics once its home and in the game room. Thanks!
To get the full of fact you're going to want to clean it up a little first. I never did shop it so it still has all the original rubber on it and it's a little dusty. Playfield is amazing though I couldn't believe it again last night when I looked at it.
This page was printed from https://pinside.com/pinball/forum/topic/laser-war-club/page/2 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
