(Topic ID: 198315)
Laser Cue - Hardly a foolish rustoration
By gutz
6 years ago
  • 109 posts
  • 41 Pinsiders participating
  • Latest reply 2 years ago by JustJared
  • Topic is favorited by 16 Pinsiders
There are 109 posts in this topic. You are on page 1 of 3.
#1 6 years ago
Sequels are never as good as the originals, but here is the worst half of the 2 pins for $0.99 eBay deal. Edit: Here is the first half of the deal if you missed it: https://pinside.com/pinball/forum/topic/sorcerer-you-are-done-mortal
Starting point is abysmal. I think at some point, the lower cab was holding water. Rust, rust everywhere, rust rust I'm starting not to care
#2 6 years ago
Yes, lower cabinet, you hold many fine treasures
#3 6 years ago
Head doesn't look good, but is still solid wood. The blue sharpie bandit has left his mark all over the cabinet.
#4 6 years ago
Wow, I thought the Bronco I'm doing was bad!
#5 6 years ago
Playfield is currently sitting outside. It's so gross, rain won't even touch it. No true before picture exists because I cleaned off the viewable area when I bought the machine years ago.
#7 6 years ago
This is either brave or insane.
I admire both.
Good luck!
#8 6 years ago
Reminds me of the pin I got from Hawaii, rust everywhere....
#9 6 years ago
Just finished restoring mine. Lmk if you need any reference pics. Probably have a few parts I can send you.
#10 6 years ago
Definitely looks like a "project" machine.
Be sure to get the metal parts all soaking in Evapo-Rust to get rid of the rust.
#11 6 years ago
I'm definitely subscribing to this. To add what Ken said, I'd probably try putting a wire wheel on a drill press (if you have one). That setup gives you a lot of flexibility on brushing rust off of larger objects.
#12 6 years ago
I wonder if these machines were sitting in New Jersey, when the storm hit a few years past....
They look like they have been submerged in salt water.
Yves
#13 6 years ago
Quoted from RCA1:
I admire both.
Good luck!
"It is a wiseman who knows when courage ends and stupidity begins"
#14 6 years ago
Quoted from bpa:
Thanks! I know I need a ball roll tilt, have one of those for sale?
#15 6 years ago
Quoted from KenLayton:
Northern tool employee scoffed/questioned me when I order the five gallon bucket
#16 6 years ago
Quoted from Arcane:
Yves
I believe that is 100% pure Nebraskan barn patina.
#17 6 years ago
ABANDON SHIP!!!
lol just kidding look forward to seeing the end result
#18 6 years ago
Quoted from gutz:
O'Reilly's Auto Parts also sells Evapo-Rust in the 5 gallon bucket as well as in 55 gallon drums!
#19 6 years ago
O'Reilly's Auto Parts also sells Evapo-Rust...in 55 gallon drums!
So you're saying I could dip the entire machine ....
#20 6 years ago
A quick once over with Novus One should get a guy right back on track.
Haha.
Good Luck Z!
#21 6 years ago
And it probably needs a fuse replaced too. Seriously, though, i admire your dedication.
#22 6 years ago
Project Pin lover here. You're a better man than I, Gunga Din! Looking forward to seeing your progress on a very Projecty Pin!
P.S. Guess what I just picked up today?
https://pinside.com/pinball/forum/topic/what-machine-did-you-bring-home-today-post-your-pictures/page/130#post-3982217
#23 6 years ago
LaserCue is a very under-rated game. I love mine!
Good luck w/ the restore. Can't wait to see the results.
#24 6 years ago
Wow. This seriously makes my restore look like the proverbial "fuse replacement".
Actually, the thing I keep thinking is how bad it must smell.
Good luck!
#25 6 years ago
I have a semi populated laser cue playfield i would sell parts off cheap if you need any.
#26 6 years ago
You are braver than I.
#27 6 years ago
Lieutenant laser cue, you got new legs! First time its been up in probably 20+ years...
#28 6 years ago
99 cents?! Not bad!
#29 6 years ago
Funk free bottom panel and painted interior. New ground braid and leg tees.
#30 6 years ago
This is the most insane set of revives I have ever seen
#31 6 years ago
Quoted from quinntopia:
Good luck!
Surprisingly, the smell wasn't that bad. I've had games that looked better but smelled worse!
I need a roll tilt, anyone have one for sale?
A picture of the departed. Remember kids, rust kills:
#32 6 years ago
I had a Laser Cue that wasn't anywhere near that bad and I parted it out. I have a lot of parts in case you need them.
#33 6 years ago
Quoted from BallyPinWiz:
Quoted from Mitch:
Awesome, thanks. For now I need a roll tilt. When I get to the playfield I'm sure the list will grow.
#34 6 years ago
Do you need just the roll tilt cage assembly, or do you need the whole white board part that the tilt parts are attached to? My white board does not look exactly like the one in your Laser Cue.
#35 6 years ago
Quoted from gutz:
No unfortunately not. I have an untested power supply, maybe some extra decals, I think a few posts and those red translucent lane covers, a backglass that is flaking at the bottom. I know I have other stuff laying around. Will check for you.
On a side note, Laser Cue is such a great game and doesn't get the respect it deserves! Here are a couple pics of the one I restored (was not as bad as what you are starting with).
#36 6 years ago
Just the roll tilt cage assembly.
And your board is different! Did yours have a knocker and bell mounted to that board?
#37 6 years ago
I can't believe that is the same cabinet!! Excellent work
#38 6 years ago
Quoted from Pinball-DOOD:
If you behave, there was actually a prequel to these two that I could share. Its not as good though, kind of like the star wars movies.
#39 6 years ago
FML (f%$# my laser cue)
#40 6 years ago
I also have the whole transformer assembly from a Lasercue if you need it. Expensive to ship though.
#41 6 years ago
When doing the dirty board hole transfer, don't be a fool - wrap your tool. Or in this case, wrap your freshly painted board.
#42 6 years ago
Following. Loved how your Sorcerer turned out and this one is off to a great start as well.
#43 6 years ago
What's your plan for exterior of cabinet? Going to repaint/stencil?
#44 6 years ago
Quoted from Pinballer22:
I think it looks pretty damn good for $0.50
(translation: Clean it and play the hell out of it )
#45 6 years ago
I would have expected less for $0.50! Going to be sweet when done! What a rescue
#46 6 years ago
Might aswell "wrap your tool" aswell, judging by how dirty that thing is.
#47 6 years ago
I'm no baker, but this feels close to a 1/4 cup of rust from the transformer panel.
#48 6 years ago
Quoted from Luzur:
You Swedes have a very different approach to game repair. You must have more women around the shop
#49 6 years ago
Quoted from gutz:
Well we dont have the bigger market of games like you guys do over there so we have to love our games abit....*shifty-eyes*.....more.
#50 6 years ago
Wow! Following, I'm in awe
$ 12.50
RoyGBev Pinball
$ 36.95
Tools
Pincoder Store
$ 9.95
This page was printed from https://pinside.com/pinball/forum/topic/laser-cue-a-foolish-rustoration and we tried optimising it for printing. Some page elements may have been deliberately hidden.
